3-Point Hitch Rock shaft - JD 110 TLB Speed control
   / Rock shaft - JD 110 TLB Speed control #1
fireout66
Nazareth Pa
John Deere 110 TLB 2007 , Bobcat 763 skid loader
I am looking for someone else who utilizes the 110 TLB 3 point not just as a backhoe. There are approximately 10 machines around my area but no one is utilizing the 3 point. This has been a challenge from the day I bought this thing. I purchased the complete 3 point from my green dealer. After i tried a used set. But the question is when utilizing the lift control on the right side of the seat even with nothing on the 3 point should the arms lift? And I also removed the seat found the rate drop control valve was seized since its steel to steel with limited access to lube. I freed the control to turn it drops like a rock ok. But no lift but had lift prior to freeing up the drop control. Is anyone familiar with this situation. I am trying to attach a woods 5 ft' brush hog and I have but raise and lower are not in its operational things to do. This loader has been garage kept since new and still only has less than 700 hrs.
   / Rock shaft - JD 110 TLB Speed control #2
The rockshaft should raise and lower whether you have an implement on it or not.
Might check the backhoe presence switch to make sure it isn't malfunctioning.
   / Rock shaft - JD 110 TLB Speed control #3
When I hooked my box blade for the first time I knew nothing about how to make it work until I pulled up on the lever that's when it went up and down for me
   / Rock shaft - JD 110 TLB Speed control #4
make sure your throttle is not at idle. Mine will not raise unless i have some at 1/4 to half throttle. More throttle faster it raises. I do not know if that is the way it is supposed to be but it is on mine.
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2012 Ford F150 Crew Cab Pickup Truck (A50323)
2012 Ford F150...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2017 PETERBILT 579 TANDEM AXLE SLEEPER (A51222)
2017 PETERBILT 579...
