Rock Bucket Drag Ideas
   / Rock Bucket Drag Ideas #1
GoodGuy
Nova Scotia, Canada
JD 4210 E-Hydro
I own a JD4210 & I'm considering some sort of rock bucket that I would drag. The reason to drag the attachment is that my loader just doesn't have the power to pick up a lot of the rock I need moved. Another reason is that I'm starting to "beat up" my bucket on the FEL because the rocks are heavy,irregular & don't push easy by no means. I have a 47 Hoe & was thinking that I could somehow use the hoe to roll the rocks into the bucket contraption & the drag them to wherever. Is there anything like this for sale or has anyone built anything like this ?? Your thoughts, pros,cons & ideas. Thanks
   / Rock Bucket Drag Ideas #3
Have you considered using a chain and draggin the rocks.
Egon
   / Rock Bucket Drag Ideas #4
I've skidded big rocks out before with chains. It works much better if you have a set of old heavy-duty tire chains. I have some from an old tractor that I've used. You wrap the rock with the tire chains; they act as sor of a basket so the rock doesn't slip out as easily as if you try to wrap a single chain around it. Then, you hook a tow chain to the tire chain wrapped around the rock and away you go.
Other than that, the upside-down hood is another good idea. Farmers around here used "stone-boats" which were just flat bottom sleds they'd load up with rocks and drag off with horses or (I assume) tractors later on.
Not too many good ways around it; rocks are a pain...
(10) 24' CORRAL PANELS (A51243)
(10) 24' CORRAL...
2022 JOHN DEERE 317G SKID STEER (A51242)
2022 JOHN DEERE...
2016 Chevrolet Impala Limited (A50120)
2016 Chevrolet...
TMA (A49461)
TMA (A49461)
Case CX210D Excavator (A50514)
Case CX210D...
Frontier FM2015 (A50120)
Frontier FM2015...
