Robin Engines on PT Equipment
   / Robin Engines on PT Equipment #1
JackRobin
Bronze Member
Chicago, IL
Hello All,
This is Jack with Robin America. It was brought to my attention today that such forum even exists. I want to take this opportunity and welcome everyone with Robin engine on their Power Trac machine.
I will be monitoring this forum as much as I possibly can, so if you have any technical questions related to Robin engines on Power Trac machines, please don't hesitate to post them in this forum.
Jack Gawecki
Robin America, Inc.
Technical Support Dept.
/forums/images/graemlins/smile.gif
   / Robin Engines on PT Equipment #2
Jack,
Welcome to the forum. As one of the Robin equipped PT-422 owners, I'm glad you're here. I hope you get a chance to take a look back through the archives and/or do a search on "Robin" in this forum to get an idea of the issues with the Robin engine. You'll be a valuable member of the forum and we promise not to ambush you /forums/images/graemlins/grin.gif
Scott
   / Robin Engines on PT Equipment #3
Welcome to the pt forum Jack , I am one of the pt owners with a Robin engine. I have had it for over three years and 545 hours with no problems. To me it has been a very good machine and engine, it would be nice if it had some more power . What spark plug do you recommend for the 22 hp. engine , mine has autolite 64 which was in the machine when I purchased it. I was wondering if a hotter plug would be available?
   / Robin Engines on PT Equipment #4
I also have a PT422 and since jack has sent me the updated starter and coils, my robin engine always starts the first time.
Great service and support. I now have over 400 hours on my PT, with no problems.
Thank you
Andrew
Thank you for the warm welcome, I'm glad to be here. /forums/images/graemlins/cool.gif
Regards,
Jack Gawecki
Robin America, Inc.
   / Robin Engines on PT Equipment #6
Hi Jack,
I echo the welcome, this speaks highly of you and Robin.
Just curious, how does Power Trac go about getting Robin's approval for their tractor design. It would seem that Robin would need to approve the engine placement design to accomodate engine cooling, muffler location, gas line routing for vapor lock considerations, vibration etc.
thanks again for being part of our Forum
Duane
To answer your question, the application review is done by two of the Japanese engineers that are working with us. Before releasing the project, they're working closely with the OEM's engineers to bring you whatever is that you've got in your machine now.
Regards,
Jack Gawecki
Robin America, Inc.
   / Robin Engines on PT Equipment #8
Welcome Jack,
I've got 'bout 85 hrs on my 22hp w/ no issues since the coil/starter update last Feb...I had spoken with you, maybe twice, on the phone back then...
Good to have you here.
Bruce Karrels
Sandwich,Il.
</font><font color="blue" class="small">( Welcome Jack,
)</font>
Thanks Bruce, and I'm glad to hear that everything is fine. Just keep on a good maintenance and this puppy will last you forever, unless something fatal will occur. /forums/images/graemlins/grin.gif
Have a great weekend!
Jack Gawecki
Robin America, Inc.
   / Robin Engines on PT Equipment #10
Jack,
I appreciate your presence representing Robin on this board. I had cold weather starting problems lat winter. This spring you sent ignition coils, a larger starter, and spark plugs. This summer I installed the starter and coils but thought I would wait till winter to replace the plugs. I noticed easy starting down to 40 degrees. Last week it 15 degrees and I had problems starting it. I remembered the new plugs and changed them. It cranked up pretty easy at 15 degrees. When it gets colder I cover the back section with a tarp and use an electric heater to warm things up before cranking. I appreciate your help and Robin's interest in successfully resolving my problems.
Now I have a couple of questions.
Will the new spark plugs damage the engine if used in warm weather? I assume it is a hotter plug. How critical is use of the correct spark plug in the Robin engine?
Does Robin have any plans to build an engine with more horsepower and the same footprint? Mine works great but if it ever wears out I wouldn't mine several extra ponies.
What does Robin think of synthetic oil? I started using it this summer with 150 hours. Seems to start easier.
Dale /forums/images/graemlins/grin.gif
CLARK GCS20MB 4K CUSHION TIRE LPG FORKLIFT (A52472)
CLARK GCS20MB 4K...
NEW Skid Steer Bolt on Hay Forks (A53002)
NEW Skid Steer...
2021 CATERPILLAR 289D3 SKID STEER (A51246)
2021 CATERPILLAR...
2019 KEESTRACK K6 SCALPING SCREENER (A51246)
2019 KEESTRACK K6...
100 GAL FUEL TANK W/PUMP (A52472)
100 GAL FUEL TANK...
