RK37 Backhoe leak down
   / RK37 Backhoe leak down #1
Fine409
RK37 Hydro Cab
Just got my tractor this pad week and have to say I致e gotten a lot of good help in this forum. My new issue is each morning when I go to use the tractor, the backhoe is sitting on the ground. Do I need to put the transport pin after each use?
   / RK37 Backhoe leak down #2
It should be on the ground when you are done for the day, or for any length of time anyway. That goes for any 3pt implement as well as the loader.
These valves leak, that's all there is to it. Some more than others, not a big deal.
There is no need to worry about leak down until it hinders the operation of the tractor. As in you consistently have to bump the control lever to raise what ever it is that is leaking down. ;)
   / RK37 Backhoe leak down #3
I make my bucket parallel the ground and just set it on an old wooden pallet that is on the ground. I havent had any issues.
Thanks. I’ve never owned or operated a backhoe before. I’m having to learn everything. It’s fun so far.
   / RK37 Backhoe leak down #5
Drop the backhoe on the ground or pin it up. I prefer to drop it because it doesn’t flat spot the tires as bad.
   / RK37 Backhoe leak down #6
Edit never mind forgot what thread I was in
That’s what I’ve done. I put both pins in. Stays put now
2007 Ford F-350 4x4 12FT. Flatbed Stake Body Truck (A48081)
2007 Ford F-350...
2000 TRAILKING TK110HDG-513 LOWBOY TRAILER (A50459)
2000 TRAILKING...
2009 IC Corporation PB105 School Bus (A48081)
2009 IC...
1989 Freightliner FLD120 (NEW CAT 3406A, NEW REAR ENDS, CLUTCH) (A51039)
1989 Freightliner...
2006 Ford F-250 4x4 Ext. Cab Pickup Truck (A48081)
2006 Ford F-250...
2014 IC Corporation PC505 Commercial Passenger Bus (A48081)
2014 IC...
