England
Has anyone hooked up a 48" King Kutter rotary cutter too a RK24? I am having trouble with the drive shaft too the pto it seems the splines are different?
That would be extremely unlikely. Especially as King Kutter private labels RK's implements.
If in doubt, take an impression of both in a bar of soft soap.
New male tractor splines mating with new female PTO shaft can be very tight. Over a period of time the splines and PTO shaft gradually wear in. However, coupling to the tractor is always a sweaty task for me.
I lube with spray Dry Lube to make slip fit easier.
Do you have a "button" or "collar" retainer, which has to be held open before PTO shaft can be pushed home on tractor splines?
If PTO drive is disengaged on tractor, you should be able to rotate tractor splines in both directions through a partial arc so tractor splines line up with PTO shaft.
