Ripper tooth for Branson BH76
   / Ripper tooth for Branson BH76 #1
ning
Elite Member
Northern California
Branson 3520h
I've been jonesing for a ripper tooth for my backhoe for years.
Turns out bxpanded.com now supports the Branson BH150 backhoe for both their quick attach and ripper tooth, and the BH76 is pretty much the BH150's previous numbering.
I ordered one of each, and got an email response the next day asking me to verify a measurement because apparently there are some "BH150" buckets out there that aren't actually sized right (BH200 buckets being stamped BH150 or something like that) - A+ to them for double-checking.
When I received the package I took off my bucket and quickly and easily mounted the quick attach unit.
The welds on the bucket on the inside of the ears interfered with the the bucket swinging into place for the quick attach and didn't allow the second pin to be slid into place. I cleaned them up a bit with a grinder (you can see where there's new black paint) - they weren't ugly per se but there definitely was more metal than necessary; I smoothed it out, leaving plenty behind for strength but got enough off so that the pin fits comfortably.
Pics:
The quick attach pins on directly in place of the bucket - using the same original pins. OEM thumb fits perfectly around it.
A new pin (provided with the QA) is placed in the bucket and the end bolted; shouldn't ever have to remove that. QA hooks on there then you lift the BH a bit, manually swing the bucket up and then the removable pin (provided) is pushed through; I'm using a lynch pin with a ring that fits really snugly around the tube.
Holes in the provided pins (permanent and removable) are larger than the holes in the OEM bucket so the bolts provided don't fit.
Shot some paint over the raw metal from the weld cleanup. Hardware store didn't have dark gray major fashion faux pas I know.
Ripper tooth installed. I haven't used it yet but expect it to revolutionize digging in my hard red clay during the dry part of the year. It should also help in digging where there's lots of rocks.
The permanent pin for the ripper was also provided with the QA (2 total). One removable pin is provided; you really only need one as it can stay with the QA on the dipper regardless of how many buckets you have.
Bucket fully in place. Ripper tooth and 20' of ⅜" chain in the bucket, it's where I usually carry the chain when I have the backhoe on the tractor.
Bucket/dipper and bucket/thumb positioning & geometry have changed slightly but I don't expect it'll be a negative.
I still intend to get a cylinder to turn the thumb hydraulic... hopefully this fall.
(ignore the toilet in the background, I haven't been to the dump since I swapped in a new one in the house)
   / Ripper tooth for Branson BH76 #2
Pics:
That's just the fresh air commode :)
   / Ripper tooth for Branson BH76 #3
Yea - adds the artsy/fartsy flare to that picture.
Otherwise - that looks to be a real good single tooth. I strip down my single bottom moldboard plow. Gives me a single tooth with a carbide tip.
   / Ripper tooth for Branson BH76 #4
You will enjoy the ripper. I usually start 10-20’ out from the stump, find the big roots and use their length as a level to fold them back toward the stump before breaking them off.
Working close to roots might want to change from lynch pins to bolt and locknut.
BX-expanded makes good stuff. Piranha bar. Tried to get them make a ripper for my Kubota B26 but not heavy enough. Company just about 10 miles from our farm.
I love the piranha bar, got it the first year I got the tractor and it's taken quite the beating and looks new. Can't imagine getting full use out of the loader bucket without it.
To be honest stump work may be done with the ripper but I'm expecting to use it more just to break up the hard ground to the point that my backhoe bucket can dig into it.
A couple summers ago I had a pony to bury (he'd had a very long life and had a very pleasant retirement) and it took me forever to get through the top couple feet where I needed to bury him (once under the sun-baked top of the ground a ways the digging got a lot better) even with bucket teeth; the ripper should make jobs like that a lot better. There's no more ponies to bury but I've put off a decent digging project because I know from previous experience what a pain it is to dig in our ground with just the bucket, the tooth should help a lot.
   / Ripper tooth for Branson BH76 #6
With your new quick attach switching from bucket to ripper and back should be a breeze now.
It's not quite the remote QA that the big excavators have, but at least by grabbing one pin with the "hook" part, you just have a bit of swinging weight to manage while you shoot the removable pin. I've elsewhere mentioned that I don't have experience pinning & unpinning buckets, but I could see how potentially wrestling a bucket around just to get the first pin in was going to be a pain which was a big part of why I hadn't just had a local welder make me a ripper (other parts of it being fifteen thousand other projects already in flight; making a ripper myself sounded fun but I just have a little 120v welder that doesn't like doing even 1/4" plate for very long)
   / Ripper tooth for Branson BH76 #8
So impressed with the ripper on the M59, adapted it the B26. Makes little hoe’s swing above their weight class.
   / Ripper tooth for Branson BH76 #10
So, could the bx ripper and narrow bucket fit the bh200 with some adapting?
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
2019 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2011 Chevrolet Cruze Sedan (A50324)
2011 Chevrolet...
2011 GMC Sierra Pickup Truck, VIN # 3GTP2WE36BG213306 (A51572)
2011 GMC Sierra...
BUYER'S PREMIUM INFO (A53084)
BUYER'S PREMIUM...
