Ring size for Ferguson T020
   / Ring size for Ferguson T020 #1
Hulaagu
Troy, Al
Ford 8600
I need to replace the rings and rod bearings in my old T020. But in looking in the online catalogs I find different ring sizes for this model. how do I know which to buy?
   / Ring size for Ferguson T020 #2
G'day if your water pump is mounted on the block then it should be 80mm if mounted to the head then 85mm, BUT the only way to really be sure is to pull the head as if it has been rebuilt at some stage it may have had the bigger bore put into it. If you need rings in one of those girls then you may as well put a complete kit of liners, bearings , pistons etc not much dearer to do it properly.
Jon
hi jon, thanks a bunch. that solved it. and thanks on the other advice, that if I can afford those puppies.
2016 CATERPILLAR 308E2 CR EXCAVATOR (A51246)
2016 CATERPILLAR...
2000 FORD F450 SUPER DUTY SINGLE CAB FLATBED TRUCK (A51406)
2000 FORD F450...
JOHN DEERE 7210R LOT IDENTIFIER 256 (A53084)
JOHN DEERE 7210R...
John Deere 6105E Tractor, 105HP, 4WD, Suspension Seat, A/C, 3 Rear Remotes (A53472)
John Deere 6105E...
UNUSED LANDHERO CHAINS & BINDERS (A51248)
UNUSED LANDHERO...
Toro Mower (A50324)
Toro Mower (A50324)
