Rims
   / Rims #1
Jimbo16720
Pa.
Bolens h1704- IH 464- Kubota L245dt
Anybody know of any other rims that would fit the Iseki G-174 tractors. Mine has 15inch wheels which I think are on 2 wheeldrive tractors. The 4wd like mine should have 16inch wheels, but what I'd like to know is wheels from any other makes of tractor that would fit.
   / Rims #2
Rims from the a Kubota will fit your tractor. I will have to look back at my posts to see which model#, but I ordered them for my G154 4wd, and they were an exact match. I'll find those for you later tonight, and post them. Take Care.
   / Rims #3
I found the original thread.
This was my response when I found the rims:
I learned a hard lesson this week. I had my front tires loaded, I don't have an FEL, and I use a dirt scoop, so I need at the weight I can get on the front. I used my impact wrench, on my original OEM rims, that came on the tractors, and I cracked them all the way around the bolts. I brought it to have it welded, and they looked at it, and said that it was not worth the money, and would be difficult to weld. I searched very hard for a new rim,a nd the only one I could come up with is one from Yenebiz, and the shipping anlone is over $200 from Europe. I did alot more research, and finally I found that the rime from a Kubota B7100, B6100, B5100 will fit perfectly, and the rims runs around $100. I had the dealer measure it, and it is a perfect match, and it even has the wheel weight holes that match up the same. I think that the rims are made by the same company in Japan for both Iseki and Kubota. I just need to paint it white when it gets here, and have the tire remounted. The part number for the tire is, 70000-00024. This site has it for $115, but I ordered it from a dealer because I wanted it to match exactly, and this rim has gaps on the inside. Anyways, i thought that you guys may be interested who have been looking for front rims. This is for the 5.00 by 12 rim size.
This is the company that I ordered them from, and below is the rim that I ordered:
Coleman Equipment - Case, Kubota, Stihl - Sales, Rental, Parts & Service
Mitch
   / Rims #4
I realized that you need the rear rims, and they should have those as well, This was my post about the rear rims:
These guys have the rear rims, and they look like they are an exact match.
http://api.viglink.com/api/click?fo...amp; Service&jsonp=vglnk_jsonp_13474239287851
Their website link does not work for pricing, but I called them with my other rim, and they were great, they wen't out to the yard and measured it. The rear rim for the TX1300F should be the same rim for the Kubota b7100HST-D old style, Not sure on the price, but it should be somewhat reasonable. You can also replace the center hub, but it looks like you need the whole rim.
Mitch
This is their part information for the rear rim:
/Kubota-B7100HST-D-OLD-TYPE-Parts/REAR-AXLE-REAR-WHEEL-33256/REAR-WHEEL-DPT-EPT-33267/
   / Rims
Thanks Mitch we have a Kubota dealer 13miles away. I'll see what they have. Jim
   / Rims
I just noticed my rims are 6 bolt not 4. They have 29-12-15 tires. Almost looks like chevy rims...4 3/4 spacing.
   / Rims #7
Do you mean your rear rims, or the front rims? My front rims have the 4 bolt pattern, and the rear have the 6 bolt pattern. The rears are 8-16, and the front's are 5.00-12. I know that some of the hydrostatic drive Bolens had what appear to be wider tires, however I think that the rear rims from yours should be the same. Mine have 4 3/4 spacing between the bolts, with 6 bolts on the rear. If that is the case, then they should be an exact match for you. Do you have a photo of your rear rims, or your tractor? This is a photo of the rims that should fit your tractor, minus the center hub. If this is the style that you have, then the Kubota rims will work. Hope we can help you find the right rims..
   / Rims
My back rims are 15inch but real deep with a wide turf tire on it. The book says it should be 8-16 but thats not what is on it. The bolt pattern would be the same. I've seen somewhere that it listed those tires and rims on the 2wd tractors. My tire size is 29-12-15 which is 29 tall 12 wide and 15 rim. And my centers don't come out they are welded from the factory.
   / Rims #9
I was wondering if you want to replace the tires, you may want to go with the 16in rims, since they will give you a bit more ground clearance, but if your tires are in good shape, I found a company that will manufacture rims for about what you would pay for pre-made rims. I think that when they started to sell the HST tractors, they offered the turf option, with a lower/wider stance for mowing. This is the link to the pre-made rims...Hope this helps a bit. Keep an eye on eBay as well.
Tractor Wheels, Tractor Rims, Implement Wheels, Tractor Wheel Rims, Rims and Tires
   / Rims
I'm almost wondering if a 6bolt chevy rim would fit. The bolt pattern seems to be right and I know they have 15 & 16 inch rims. The only problem might be the size of the bolt holes. Plus a taller tire would give a little more speed in high gear. I might have to look into that. My tires are like brand new, but living in NPa. we get snow and would like to get some Ag Tires for plowing. Be nice to just switch wheels with tires already on them.
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A50323)
2015 Ram 3500 4x4...
2018 JLG 2632ES 26FT Electric Scissor Lift (A50322)
2018 JLG 2632ES...
2018 Dodge Journey SUV (A50324)
2018 Dodge Journey...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
