RimGuard Lifespan
/ RimGuard Lifespan #1
TexasBoy
Central Texas
Kubota M7060HDC12, L4600DT, Ford 4000
Ive been thinking about putting RimGuard in my rear tires, but was wondering about longevity. Does that stuff break-down and change over time? Do any precipitates form and fall out of the solution over the years?
The specs on that stuff look very good, but Im wondering how long will it remain in the same state over time.
/ RimGuard Lifespan #2
I have over 10 years with the stuff and all I can really say is that my tires are still round and black. Good question though, looking forward to other feedback.
/ RimGuard Lifespan #3
Have had rim guard in all my tractors' rear tires without any problem
/ RimGuard Lifespan #4
I'm also subscribing. I just got quotes to fill my rear tires and I plan to get the tractor to the tire shop on my next weekday off.
/ RimGuard Lifespan
Oh I dont doubt the stuff works, but unless someone opens up a tire after many years and looks, a person really doesnt know what is happening in there.
Its been my experience with solutions (of many types) they work great for a given time frame, but as the years go by the mix breaks down and precipitates fall out and it all just eventually breaks down. You can end up with chunks of stuff floating around in there, sediments, and the characteristics of the solution changes and not perform as it once did. (ie: lose its anti corrosive traits and eventually start eating up or rusting the wheel) I looked on the RimGuard website FAQ and saw nothing about life span.
Thats the beauty of glycol based anti-freeze products is they have pH additives to help with corrosivity and Im sure there are published specs on how it behaves over time. While glycol anti-freezes might work okay as ballast, I wouldnt imagine they would stay in the correct pH range for just too long. (relatively speaking)
/ RimGuard Lifespan #6
I've got Rimguard in my tractors. If I had to do it again, I would of used foam. I hate checking the air pressure on a Rimguard filled tire.
/ RimGuard Lifespan #7
I asked about foam, but the tire shops I asked all told me that it was ridiculously expensive. They didn't even think it would be worth giving me a number.
/ RimGuard Lifespan #12
I have beet juice in my tires- I assume it is rim guard, but I don't know as I bought the tractor used. The tractor is a 2003 with all of the dealers decals. The temp here has been -34F. No freeze up yet. I like beet juice. It does not corrode like calcium chloride does. If the tire ever gets sliced open, I know that I won't have antifreeze all over the ground. Beet juice is a sugar byproduct (all of that white (beet) sugar we buy in the store. Does great.
/ RimGuard Lifespan #13
Just curious-why?
/ RimGuard Lifespan #14
Just curious-why?
Rimguard is the re-dissolved solids left after sugar is extracted from beets. It is beet-red and fairly sticky/viscous. He's probably talking about the syrupy goop that escapes when he checks the pressure.
I wouldn't put my good tire gauge on a tire filled with it...
/ RimGuard Lifespan #15
Is there a temp that rim guard will freeze?
I've been quite concerned about this, myself.
In the Northeast, my "inside storage" will consist of a "high cube" (9.5" H) by 8'W by 20' L, international shipping container, sitting on (sunken) 6"x6", so the container's frame is almost touching the ground--however, it has a wooden floor.
But one door is "sprung," leaving a 2.5" gap, all the way up (9.5'), when "closed."
Meaning, I can't just put the "proverbial light bulb" in there, to keep the Rimguard from freezing.
I'm told Rimguard actually has a freezing point that is a few degrees LOWER than water, which is great, but will NOT help me, I fear, in successive nights of near-zero temps.
I do NOT relish the idea of plowing snow (on frozen lawn and macadam driveway) with FLAT SPOTTED rears shaking the **** out of my beatiful, cabbed CUT.
Is there any "antifreeze" that can be added to Rimguard, that will:
a) Lower the freezing temp to, say, -10F or lower, and
b) NOT cause the rims to rust? (Which I'm told is one advantage of Rimguard, i.e., that it does NOT rust your rims?)
Thanks much,
My Hoe
/ RimGuard Lifespan #16
Thanks much,
My Hoe
Rimguard's freezing point is below -35F. You shouldn't have anything to worry about.
/ RimGuard Lifespan #17
Just curious-why?
I would go with foam because once the tires are foamed, they are puncture proof. Secondly, with Rimguard-filled tires, you still have to maintain an air pressure. Checking the pressure is a pain in these tires. You have to spin the tires until the valves are at 12:00 o'clock. And beet juice remnants always spits out. You have to use a liquid air gage, not your standard air gage. The older I get, the more maintainance free the better.
/ RimGuard Lifespan #18
WOW! Negative 35F? That's awesome!
Somehow, I thought Rimguard was only good for a few degrees below the freezing point of water--probably because I misread the "-35F" as "35F". But wait, that's goofy too, b/c 35F is warmer than 32F. Oh, well, who cares how I screwed up. I'm just REALLY glad I was wrong.
-35F is GREAT!
Thanks, Parkanzky!
AStanton,
I apologize--I wasn't clear. The tractor I'm talking about is already filled with Rimguard. Otherwise, I might consider foam--though I've read that foam rides harder than liquid filled, and I've had back surgery, so if foam is a rougher ride, I'll gladly trade that for the legitimate concerns you raise.
And I admit that not having to worry about flats anymore would be a big blessing.
Oh well--most things are a compromise, right?
Thanks again, gentlemen!
My Hoe
/ RimGuard Lifespan #19
Beet juice also turns to slush a fair bit before freezing. I believe their listed freeze point is where it turns to slush, not solid. Slush doesn't present near the problems that freezing solid does so its even better than indicated temp wise.
/ RimGuard Lifespan #20
I have had it in my tires about 6 years, so far so good, but I agree, a pain to check tire pressure.
SDLD25 MINI DUMPER (A58214)
SDLD25 MINI DUMPER...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2013 COACHMEN CATALINA TRAVEL TRAILER (A55745)
2013 COACHMEN...
GREENHECK AIR DUCT FAN (A60432)
GREENHECK AIR DUCT...
2003 Freightiner FLD120 (A61306)
2003 Freightiner...
UNUSED IRANCH 20CM TOOTHBED MINI EXCAVATOR BUCKET (A60432)
UNUSED IRANCH 20CM...
