Rims Rim size on a Kubota L4400DT.
   / Rim size on a Kubota L4400DT. #1
Mikerobe
Bahamas
Kubota L4400DT
Good evening,
I'm trying to determine the correct size of the rear rims on my Kubota L4400. The parts manual doesn't give specifics for the rim sizes either.
The tires are Titan 17.5L-24 R-4.
The actual dimensions on the rims are as follows:
Diameter(measured bead to bead) 24".
Width(measured bead to bead) 16".
What size rims do I have? I've searched for days looking for rim sizes as 17.5 x 24, 16 x 24, 15 x 24. No such rim exists apparently!:confused:
Any help much appreciated!
   / Rim size on a Kubota L4400DT. #2
Call Miller Tire, we can help. 800-621-1955, Mon-Fri, 8am-5pm EST, ask for Ed
   / Rim size on a Kubota L4400DT. #3
Don't know about the L4400, but our L3130 has the rim size stamped on the rims... I'd guess yours does, somewhere?
   / Rim size on a Kubota L4400DT. #4
With that size tire it should go on a 15 x 24 wheel. They mostly came with a two piece wheel with a demountable center know as a Z clamp wheel, it had 6 of them evenly spaced around the wheel and the bracket was so that you can bolt the center disc in at several different offsets !
Are you looking for some ?
Safety Basket (A50121)
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A52748)
2021 John Deere...
2025 Swict 84in Bucket Skid Steer Attachment (A51691)
2025 Swict 84in...
2014 Bobcat 15C Skidloader PHD (A50774)
2014 Bobcat 15C...
Unused 2025 CFG QK20R Mini Excavator (A50322)
Unused 2025 CFG...
