Rotary Cutter Right size rotary cutter for a Kubota L4400
Status
Not open for further replies.
   / Right size rotary cutter for a Kubota L4400 #1
kgroesch
Texas
Kubota L4400 DT
I have been researching tractors and attachements for the past year with this forum being very helpful. I believe I have decided on a Kubota L4400 tractor w/ FEL and 4WD. I am now looking for the right sized rotary cutter.
My application is 48 acres of pine timber with a fire break around the perimeter. I need to mow the fire break once a year which just about any rotary cutter would manage. However, I have some large areas of heavy brush that I want to open up and would like to get the heaviest duty cutter that an L4400 can manage well. After a timber cut I will also have a lot of limbs that would be nice to shred up. On other threads I saw that the Owner's manual of the L4400 recommends a max weight of 880 pounds for a rotary cutter attachment which greatly limits how heavy duty of a cutter I could purchase. I am looking now at a Bush Hog 295 5' deck and a Bush Hog Squealer SQ172 6' deck. The 295 can handle about 1" thicker material (up to 2.5-3") depending on if you read the owner's manual or the specification sheet. However the 5' deck will not extend past the tires on an L4400 which has a width of about 62.4". I will be working in a lot of tight spaces so I am not sure that is a bad thing but the dealer I have been working with says I will be sorry if I don't get a 6' deck to allow a little overhang. Especially for cutting up against a fence. The 6' deck I don't believe will greatly reduce my cutting time as I don't have wide open fields to cut. Just a 15-20 foot wide fire break. I also don't mind leaving a little grass along the fence line.
I am leaning towards the 5' deck just to handle the thicker brush but am looking for some suggestions from people with experience to see if I am making the right decision.
   / Right size rotary cutter for a Kubota L4400 #2
Duplicate thread. Closed.
Status
UNUSED FUTURE PAIR OF MINI RUBBER TRACKS (A51244)
UNUSED FUTURE PAIR...
2020 CATERPILLAR 259D3 SKID STEER (A51242)
2020 CATERPILLAR...
2020 Hisun 750 CCEFI UTV (A50514)
2020 Hisun 750...
Informational Lot - Shipping (A52128)
Informational Lot...
Payment Terms (MUST READ) (A50774)
Payment Terms...
