right implement for smoothing frozen ground
   / right implement for smoothing frozen ground #1
CurtC
Indian River, MI
Shopping, Kioti CK30, Farmall 450D previously
With the weather extremes, I've got some paddocks that got mushy, are all chopped up and now frozen hard.
I've been cleaning them up some with a back blade, but it's not particularly effective, and it's beating the snot out of the blade.
I figure someone on here has this same problem, looking for comments on what works for you for maintaining frozen paddocks.
Thanks!
   / right implement for smoothing frozen ground #2
Well, I'll probably never have that problem here in FL, but I think the answer is, wait until spring when it's thawed!! /forums/images/graemlins/grin.gif John
</font><font color="blue" class="small">( Well, I'll probably never have that problem here in FL, but I think the answer is, wait until spring when it's thawed!! /forums/images/graemlins/grin.gif John )</font>
Unfortunately that's simply not an option with 13 horses hobbling around. /forums/images/graemlins/smile.gif
   / right implement for smoothing frozen ground #4
I would look into the Arena Rascal or the TR3 Rake Arena Rascal. Give them a call to inquire about using these tools on frozen ground.
JackIL
   / right implement for smoothing frozen ground #5
You need something with lotsa beef like a rollover blade or a pulverizer.
Gabby
   / right implement for smoothing frozen ground #6
I have the same problem.. when it freezes.. the steers have a hard time walking on it.. probably is not too good for their hooves either.
I use my FEL w/ out the toothbar... curl it back.. go backwards and slice the frozen bumps off. This is suppose to be a no-no w/ the FEL.. but I go slow.. it works good.
I would try it at the warmest part of the day.. even though it is still freezing.. the sun will soften some. I could tell the steers were a lot happier w/ better footing.
   / right implement for smoothing frozen ground #7
Curt, I don't have horses but my daughter rides at a stable near us. This is obviously a serious issue because you don't want a horse to break a leg on that uneven ground. They have a similar problem and they seems to use multiple implements. A heavy box blade with scarifiers followed by some sort of pulvariser or heavy harrow may do the trick for you. The stable my daughter rides at tries to groom the ground at the doors as the temperature drops rather than getting it after it is frozen solid.
   / right implement for smoothing frozen ground #8
I'm not sure how hard you other guys bumps get, but when the temp is around zero for a few days, nothing that I have that scrapes, including an 8'box blade on a TN and a bucket will even touch the bumps. The only thing I have found that will is the carbide teeth on a Harley rake.
Andy
   / right implement for smoothing frozen ground #9
<font color="blue"> what works for you for maintaining frozen paddocks. </font>
sorry bout this answer .... just feel like I gotta .... <font color="red">A Moving Van headed south! </font> /forums/images/graemlins/grin.gif
   / right implement for smoothing frozen ground #10
Around here nothing short of a D6 is going to flatten the frozen ground. We're in a cold spell, with lows below zero and the highs not getting out of the single digits.
I'd bring in a few loads of sand and get it spread before in freezes up.
2011 Chevrolet Camaro Convertible Coupe (A52377)
2011 Chevrolet...
2021 Doyle 8 Ton Trailer Tender (A53472)
2021 Doyle 8 Ton...
2019 Freightliner M2 106 Recycling Truck (A51692)
2019 Freightliner...
2016 Case CX160D Hydraulic Excavator (A51691)
2016 Case CX160D...
Echo SRM2620 Gas Trimmer (A52377)
Echo SRM2620 Gas...
