Right Carburetor for a Ford 2600
   / Right Carburetor for a Ford 2600 #1
Bladerunner6
Elizabeth City, NC
John Deere 950, and John Deere 5065E w/553 Loader, John Deere Gator XUV 825M
I have been having one problem after the other with my Ford 2600. I posted last summer about problems with it starting then dying. I thought it might be the fuel pump, so I ordered one and it turned out to be the wrong part. I just cleaned out the old one really good and reinstalled it.
It would crank after that and even ran for a couple of days like it should. Then it started to run very weak and would die if I put it in gear. Then I noticed that while running, gasoline was leaking badly out of the round plate on the bottom of the carburetor. That lead me to order a carburetor rebuild kit thinking I could do it myself. Well that was disastrous with me quickly realizing that I was in way over my head. I am not sure it was even the right kit, even though it was sold as a kit for a Holley Carburetor for the 2600 3 cylinder gas engine. I sure ended up with a lot of spare pieces if that was the right kit. There were pieces in the rebuild kit bearing no resemblance to anything I found on the original carburetor.
OK, now here I am wanting to get this thing fixed and have been looking for a replacement carburetor on line. After my experience/failure with getting the right parts (fuel pump, carburetor rebuild kit) on line, I am now scared that I am going to get the wrong carburetor for the 2600.
I found this one on "Yesterdays Tractor.com", but wanted to check with you guys to make sure this was the right one. It appears from this listing that there was only 1 carburetor used on the 2600 throughout its period of manufacture. Is that correct?
Ford 2600 Carburetor (13914)
I think everyone should be able to sense, that I am not very mechanically inclined. I would appreciate any advise on this.
   / Right Carburetor for a Ford 2600 #2
that carb you linked to is a zenith. the original likely was a holley. The holley are finicky.. they like only their specific rebuild kit. have tractor number and model code on hand to get the kit. otherwise.. yeah.. the zenith will work fine. Not as fuel miserly as a holley.. but a lil less finicky. ( though spendy! )
2014 UTILITY 53X102 DRY VAN TRAILER (A52141)
2014 UTILITY...
CPS 185 KD8 PORTABLE AIR COMPRESSOR (A52472)
CPS 185 KD8...
John Deere Gator 825i 4x4 Utility Cart (A50322)
John Deere Gator...
2008 Ford F-250 (A52748)
2008 Ford F-250...
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
Unused 2025 CFG QK18R Mini Excavator (A50322)
Unused 2025 CFG...
