Right angle drive seizing?
   / Right angle drive seizing? #1
ioldanach
I have an MTD 190-032 that's now on its third winter on a little cub cadet LT1045. Always has something that needs maintaining, but yesterday I had a whole new problem.
We had only about 5" of snow fall yesterday, but that was quickly followed by quite a bit of freezing rain which saturated the snow and made it very heavy. Unfortunately, I couldn't get home early enough and had to move this heavy, thick snow from my 300' or so of driveway. If I drove too slow, the snow just clogged up the chute, but if I drove a little quicker, so it was getting more snow to the impeller, the impeller quite happily shot this thick stream of snow about 8 feet up and 10 feet to the side. So, I did the half of the driveway that's the hill (I always do this part first, so if the machine breaks down at least we can climb the hard part of the driveway) and then started working on the level portion that heads out to the street. On the return pass from the street, I'm 90% done with the driveway, and I get smoke and hot belt smell coming from the drive pulley that attaches to the right angle drive mechanism.
I gave it a few minutes to cool and drove the unit up in front of my garage, and re-engage the blower for a moment. The impeller and augers spin up and clear themselves of snow, but the smell and smoke quickly come back and I can't tell if they might be spinning a bit slower than normal. I killed everything, and checked the belt tension, which seems just fine.
Now, I was really working the machine hard with this snow, so I'm wondering if the right angle drive has begun to seize, or if the reducer transmission that turns the augers has begun to seize. There are no instructions in the manual about greasing these, so I don't know what grease I should be using or how to go about greasing them.
Any suggestions on what to grease or lubricate these two things with, and which one I should start with?
   / Right angle drive seizing? #2
Im not 100% familiar with your MTD, My honda takes gear oil in the right angle drive. Yours is probably similar. Pull the cover off and see what comes out. (if its grease or oil). You probably glazed the belt pretty bad with the snow and thats the reason for your problems. Get yourself a new belt your old one is likely done. You should be able to spin your auger by hand, give it a try and see how it feels. It should be stiff (due to the mass of the auger and impeller) but should still turn "free". When you pull off the cover for your right angle drive check for metal. Its possible that you could have a siezed bearing for your auger. If you open your rt drive and it looks ok, but the auger is hard turning by hand, id check the auger bearings .
Hope that helps.
2803 (A50460)
2803 (A50460)
2019 John Deere 204L (A47477)
2019 John Deere...
2014 Infiniti QX60 (A51694)
2014 Infiniti QX60...
2015 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A51692)
2015 Peterbilt 320...
2025 SDLANCH SDLE18P UNUSED Mini Excavator (A53117)
2025 SDLANCH...
2012 Honda Pilot SUV (A51694)
2012 Honda Pilot...
