Riding mower recommendation for hills
   / Riding mower recommendation for hills #1
esf_joe
I need a durable riding lawn mover that can handle difficult hills and tight spots. I need to mow about an acre with a 30 degree slope and another acre in a garden area. Since, I will only use the equipment for mowing I would like to avoid spending a significant amount of money.
My own research indicates that to meet my requirmements I need at least a JD 500 series or Kubota GR 2110. I have not reviewed other brands. Can anyone confirm my research and/or offer alternatives.
Thanks,
   / Riding mower recommendation for hills #2
Thou it sounds like you want a tractor style, you might try the tread labeled "Which is better for mowing on hills, ZTR or SCUT?" in the owner operator section. There are some really good points brought up.
Good luck, Dave
   / Riding mower recommendation for hills #3
The best hillside mower is a Steiner or Venntrac, but both of them may be a bit more than you wish to spend. Most newer LG tractors do pretty well on steep hills. I would prefer the Kubota over the X500 JD here as it offers all wheel drive in a smaller package. The X 500 with the diff lock is quite stable on hills, though and I think a bit better overall machine. The ultimate conventional tractor for this work is an Xseries JD, preferably with four wheel steer. They stick like glue to almost any hillside, but again are pretty expensive to buy. Another option is to find a used Gravely Garden Tractor. They have not been made for some years but are really durable and there are still some around. They are extremely stable on hills and cut really well. My dad still has one, one of the best machines we have ever had.
John M
   / Riding mower recommendation for hills #4
John M
Get front mount ZTR.
   / Riding mower recommendation for hills #5
This is a good point, front mount ZTR's do offer excellent hillside stability. In fact, I should have mentioned most all ZTR's offer good hillside stability--to a point. One concern about all ZTR's I have is that they are quite stable but when they go they go in a big way and are nearly impossible to control. I personally have had two near death experiences with a center mower and front cut ZTR and would say both have their limits. So long as your hillside is not too steep and fairly smooth across its face, you should be fine. Good point made here, though.
John M
   / Riding mower recommendation for hills #6
Thanks,
I have found the best on slopes is the AWS (all wheel steer) lawn tractor. Having good traction to turn on a side hill has been a great feature (and admit it was a surprise) of the AWS.
Have over the last 18 years, had AWS in the Deere 425, 445, and X487 with 54" and 60" decks.
Rare to ever have to use the posi-traction lock.
Give one a trial run and see what your take is, and I think you will be happy with the results.
Get one where part of the fanny can slide uphill off the seat, as it is more comfortable than hanging on while in the center of the seat. That goes for any rig, IMO. :)
   / Riding mower recommendation for hills #7
Thanks,
You're on the right track.No 2-wheel drive machine will hold safely at 30deg,up-down or sideways.I use the Kubota GR gas model on this nasty 30deg hill(bank,actually).Cheapest thing I could find to get the job done.
   / Riding mower recommendation for hills #8
A 30 degree slope is beyond the ability of most 2 wheel drive lawn tractors or ZTRs. It is also a recipe for a roll over, so you might want a ROPS on what ever you buy. I had cut lawns commercially for over 6 years, acres of lawn per DAY all week long when I was a young whipper snapper. I won't operate a riding mower, garden tractor or ZTR at 30 degrees myself, it's beyond my personal "pucker factor".
   / Riding mower recommendation for hills #9
Simplicity also now makes 4WD YTs & GTs that are below the Legacy XL line. A Conquest 4WD with a 23hp B&S Vanguard V-twin and 50" deck lists for $7050. As best I can tell, the major difference between the Conquest 4WD and Prestige 4WD is $900 and the Prestige has a 27hp Kohler Command V-twin and hydraulic lift. Both models have the same transaxle, deck, and power steering.
I'm just presenting this as another option to the GR2100/2110 and JD X series mowers. If you have a local Simplicity dealer, I'd check them out, if not then I'd stick to brands with local support.
Yard & Garden Tractors / Products / Simplicity
   / Riding mower recommendation for hills #10
That is only partially true. True is that two wheel ZTR or tractor will not make it uphill due to loss of traction. But front mounted ZRT is impossible to flip over even on much steeper slope. They slide but not flip. We mow a pond dam slope about 300 ft long and 50 ft wide with angle 25 to 30 deg. I can go straight down but to save on number of passes (rounds) I usually go diagonally down. The ZTR is somewhat directionally unstable but not beyond ability to control it. I believe, if I could some way increase traction it would climb up make a U turn on the slope and come straight down. Tractor can't come even close to stability of front mounted ZTR. Mid mounted ZTRs as well as tractors can flip backward going up.
Terms and Conditions (A42021)
Terms and...
2018 KCM 40ZV-2A Wheel Loader (A42742)
2018 KCM 40ZV-2A...
2017 Jeep Compass SUV (A42744)
2017 Jeep Compass...
2021 Chevrolet Traverse LT SUV (A42744)
2021 Chevrolet...
PORTER CABLE 150 PSI AIR COMPRESSOR (A45333)
PORTER CABLE 150...
2014 Peterbilt 337 Forestry Grapple Truck (A42742)
2014 Peterbilt 337...
