Anyone know of an inexpensive way to repair a worn out electric pto clutch on my lawntractor Husquarvarn lt145?
Im tired of dumping money into this ancient mower and the clutches are 250 bucks parts only.
Do these clutches have the adjustable air gap on them? I.e. three or four spring loaded bolts on the perimeter? If yes keep this airgap adjusted to around .010 inches. It will make the clutches last a lot longer. Also keep them adjusted evenly. I.e. same air gap at all of the adjusting points.
To much air gap and the clutch does not engage fully which causes the coil to overheat and also allows the clutch plates to slip under load which increases the air gap.
Good luck
Roy
and Jinman, you must be kidding, A/C clutches go out all the time, I think that was my first set of specialized automotive tools I bought in my teens was the A/C clutch removal tools...lol, and put them into good use. Not a bad idea however.
Maybe I should have said, "By comparison, A/C clutches are more reliable." I have never had an AC clutch fail with over a dozen AC cars/pickups owned. Those clutches open and close thousands of times during their lives because they cycle on/off with the thermostat. I'm sure they do fail and an AC repairman would see only the failures. I just think that the majority of them are much more reliable than some lawnmower PTO electric clutches. I don't know if they are as strong, but I do think they are more reliable.
