Ridding property of stinging pests?
   / Ridding property of stinging pests? #1
Renob
Finger Lakes, NY
Kubota B2620 TLB
What is the best treatment/method to prevent paper wasps, for the most part, taking up residence in every shutter, deck, eave, tree, bush, sill, you name it - on your property. Did I say we get a lot of wasps..........We get a lot of wasps!!!!!!!!! The pests!!!!!!!!!!!!!
   / Ridding property of stinging pests? #2
For the house I've been able to substantially cut down on wasps by spraying the eves, window frames and other likely spots every 60-90 days with Cynoff WP which I also use for inside pest control. It kills the active ones and seems to deter them from coming back.
I purchase mine from Epestsupply.com
Add Your Item
/Todd
Thanks for the quick reply and link to their site. Unfortunately not available in our communist State of New York! Any other ideas?
   / Ridding property of stinging pests? #4
I get wasps inside my eve's and I can spot them by increased number flying around at different spots around my house. I can't reach the nest from outside so after dark ,the later the better I sneak into the atic with my flashlight and a couple of cans of that wasp spray that squirts 20 feet. I can spot the nest from the center of the atic and with all the wasp on the nest I can wipe out the whole bunch. That seems to take care of my wasp problem for at least two maybe three months.
I tried this method early in the morning at first and it didn't work. The wasp would be back in a matter of days using the same nest. I guess some left the nest before I got out of bed.
   / Ridding property of stinging pests? #5
Have any relatives that live out of state? :)
Seriously though, I'd look for another pesticide that has a good residual effect.
Give the folks at Epestsupply.com a call and ask their advice.
Ask A Pest Control Professional A Question
/Todd
   / Ridding property of stinging pests? #6
First of all, the common paper wasp that builds the open nest that looks like an upside down hole filled gray mushroom is not terribly aggressive. These guys eat a lot of mosquitoes and other pesty critters, so if they aren't somewhere that you will be getting too close to very often, you might want to leave them be.
If, on the other hand, you're dealing with the critters that build the big gray basketball nests, those are white faced hornets, and are somewhat more aggressive tenants than the "polistes" wasps. Still, they do eat a lot of pesty small insects, and if you can tolerate them being possessive of the area around their nest, you're ahead of the game to leave them alone.
If the critters show up inside, you need to seal cracks all around the house. You're probably spending more each year on lost heat or A/C than the caulking will cost to seal the house up.
I live in a log home. When we moved in, carpenter bees were a big problem. These guys eat a nice round 1/2" diameter hole into your house, especially pine, spruce, and fir wood species. Left alone they can eventually leave a twisting tunnel about 2 feet long inside a 2 x 6, which of course does no good for the structural integrity of the house.
When we had the place stained, the painter used Sherwin Williams stain and put a S.W. product in the stain to keep them away. The stuff is called "bug juice" and works very well. We have had no carpenter bees for two years now. We get no nests from their relatives, either. It isn't cheap, but you need very little of it -- something like 1/4 ounce per gallon of paint if I remember rightly. I don't know if you want to paint your eaves, but contact your S.W. dealer about the product. It might even be legal in New York!
   / Ridding property of stinging pests? #7
The stinging insects I hate are yellow jackets. It is amazing the places they take up residence. They have a problem with noises like lawn mowers, weed whackers and brush cutters. I have been nailed several times. If I see them before they get me, I get them. A quart of petroleum product poured in the in ground nests after sun down does the trick. The other stingers I leave alone if they leave me alone because I hate mosquitoes almost as much as I do yellow jackets.
   / Ridding property of stinging pests? #8
I had a bunch of wasps this Spring building nests all around my house,too. I used an insecticide made by Bayer that I'm sure I got at Lowe's that worked well for me. It is a liquid that you mix and put in a pump sprayer. It doesn't kill instantly - but they don't come back and try to build in the same spot again.
So far I think I'm rid of them.....so far.
I'm curious if anyone has ever tried any of these things?
The Original Waspinator
They are "artificial" wasp nests. Supposedly wasps are very territorial and won't build where there is already another nest in the area. Seems like a good solution for decks and patios or areas you don't want to spray.
hud
   / Ridding property of stinging pests? #9
Interesting concept! I wonder if you have the territorial effect on different species, or just the ones whose nest looks like the waspinator? I also wonder if the waspinator is impregnated with pheromones in addition to the visual aspect.
   / Ridding property of stinging pests? #10
Not sure about the similarities of the nests. The "testimonials" on the website mention wasps, "bumblebees" and yellowjackets being deterred by the Waspinator. I've never seen a "bumblebee" nest and as far as I know yellowjackets build in the ground so maybe the idea of territoriality of the diffent species holds up.....?
As to the phermones, I'm not sure. There are several mentions on the site about how these insects are visually oriented and in one case it was mentioned that the phermones of dead wasps tend to attract other wasps.
I'm going to buy a couple of these things for my decks and outbuildings, I think.
I'd sure like to hear a first hand account from a good ol' tractor owner here before I spend the loot.
That's a lot of beer money!:D
hud
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
1827 (A51248)
1827 (A51248)
2004 Lull 944E-42 Telehandler (A53117)
2004 Lull 944E-42...
METAL FILING CABINET (A53843)
METAL FILING...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2019 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A54607)
2019 FREIGHTLINER...
