Jerry/MT
Elite Member
- Joined
- Feb 2, 2008
- Messages
- 3,141
- Location
- North Idaho-The Palouse
- Tractor
- New Holland TD95D, Ford 4610 & Kubota M4500
RickB:
I just purchased a used New Holland 688 baler with both net and twine wrap. It has never been used for twine and I don't intend to start either. I got the wire harness with the Bale Command II monitor but I don't have the power supply harness. I looked up the part number and found it to be New Holland part # 86509520. I have a few questions I'm sure you can answer.
Does this harness come with a circuit breaker/fuse? What is the length of the harness since it has to run from the battery or the starter solenoid battery connection to the back of the tractor so I assume it's long enough to do that.
Is the hardware available to mount the Bale Command monitor in the TD95D cab? If so, what do I attach it to? It looks like what I call a "spade mount" and the tractor side is the female receptacle for the spade mounted on the Bale Command monitor. The only viable place to mount it looks like the steel piece at the bottom of the front windshield of the cab. Got a part number for the female side?
Thanks in advance.
Thanks in advance.
