Rhino TW72 Rear Wheel Question
/ Rhino TW72 Rear Wheel Question #1
GaryC
Southlake Texas
New Holland TC45D SS
The rear wheel on my shredder has locked up due to a lack of use. I cannot get grease into the grease fittings. If I use WD40 and a sledge hammer I can work it loose, but it locks up again when I use it the next time. Is it relatively easy to get the wheel off so the dried/hardened grease can be cleaned out so we can reapply fresh grease? And if so, can anyone guide me on the easiest way to do it? Thank you in advance.
/ Rhino TW72 Rear Wheel Question #2
Do you have your owner's manual? That should tell you how to remove it.
If I'm reading your post correctly, the tail wheel doesn't pivot...but the wheel does turn, is that correct?
Anyway, per the Rhino manual (downloaded...if you don't have your manual, go to this page and download Manual 00759048C), there is a pin the needs to be driven out. You see that pin atop the pivoting part of the tail wheel assembly.
I do expect you'll need some penetrating oil and perhaps something to drive that shaft out.
Since you can break it loose, then it binds up again, I suggest you look for any distortion or bending of that shaft.
If it's the wheel itself that doesn't turn...well, the manual doesn't go into that disassembly. That indicates the assembly isn't meant to be disassembled by the owner-operator. If you've any mechanical skills, you may figure out how to tear that assembly down. I would not be surprised if some of the components are pressed into place though.
Thank you. Every thing makes sense and I'm anxious to see if it works. I appreciate you taking the time to respond.
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
UNUSED ATS POWER ATS-MIG-140 MIG WELDING MACHINE (A64281)
UNUSED ATS POWER...
2025 SDLANCH IRET13 Electric Tricycle (A64194)
2025 SDLANCH...
CASE INTERNATIONAL 3900 DISC HARROW (A63291)
CASE INTERNATIONAL...
2014 INTERNATIONAL DURASTER 4300 EXT CAB DUMP TRK (A62130)
2014 INTERNATIONAL...
2025 JMR Stump Bucket Skid Steer Attachment (A61572)
2025 JMR Stump...
