Rhino TS12 drive shaft greasing.
   / Rhino TS12 drive shaft greasing. #1
JimHam
Bronze Member
Duffield, VA
Kubota M8200DTC
Doing spring maintenance on my new (last year) Rhino TS 12 batwing and had a question about the drive shaft. Owners manual shows grease zerk on the shaft with an opening in the shaft cover to access it. The hole is there in the cover but after several attempts I can find no grease zerk anywhere on the shaft. The shaft is already showing wear where it telescopes. It's a pain to remove the plastic safety cover to lubricate every time I mow. Anyone own one of these mowers that can help me out?
IH 480 18' Disk (A50515)
IH 480 18' Disk...
Pro Tech 16' Snowbox (A50774)
Pro Tech 16'...
Toro Workman Utility Cart (A51694)
Toro Workman...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
Gehl 960 Silage Wagon (A50515)
Gehl 960 Silage...
10ft Fork Extensions (A50322)
10ft Fork...
