Tractor: Kitoti DK45SE (35 PTO HP I believe)
I have narrowed my choices down to 3 cutters and either Land Pride or Rhino.
Only those two brands due to availability/support in my area.
The Rhino has a RH6 and LP is model 1272 (both have pretty much same specs)
LP also has an 1872 (Rhino has a comparable model but cost to much and is pushing the min PTO HP req'd of my tractor, not sure why the LP has such a large range of HP their 1872 mower can be used on but the Rhino version has such a high min for PTO HP)
Is there any reason really to look at the LP 1872 when it weighs 170lbs more?
Wouldn't the 1872 just be more wear and tear on the tractor over time since the tractor has to work harder to make it cut?
The RH6 has an oval blade carrier, the 1272 has a round, does that matter?
I am mostly cutting grass, brush, & saplings, nothing over 1", anything larger I will just cut by hand.
I have 40 acres, not all mowable of course
thanks for any advice.
