Rotary Cutter rhino fr15 flex wing
   / rhino fr15 flex wing #1
johnvickl
Bronze Member
I have a kubota m7040 2 remotes, can I run a rhino fr15 that has 3 hoses? Thanks
   / rhino fr15 flex wing #2
The answer should be yes. I am not specifically familiar with that mower. However, on most batwing mowers, there should be a pair (2) hoses for the main lift cylinder, which is in most cases a 2 way cylinder. This will occupy 1 set (pair) of your tractor hydraulic couplers. The other single hose should go to the rear of the mower and will split with a "T" into a single hose for each wing cylinder, which are usually 1 way cylinders. This single hose will go into only one of the remaining pair of hydraulic outlets. The wings usually go down by gravity and therefore only require a 1 way cylinder.
On many batwings, there may be an optional individual hose for each wing cylinder and each wing can be operated by a separate tractor hydraulic. If this was the case with your mower, you would see 4 hoses and it would require 3 pairs of rear tractor hydraulics- one pair of oultets for the main lift cylinder and 1 separate outlet for each wing.
   / rhino fr15 flex wing #3
All the cylinders are 1 way and go down with gravity. Just "T" the wing cylinders together like radman1 said.
Ok thanks I used a land pride 3315 had 2 hoses one for the mower up and down amd one for both wings. I just don't want to add another remote. I'm still looking for a batwing. Most people like rhino or bush hog. Checking on John Deere and modern ag predator don't know alot about modern ag
2602 (A50322)
2602 (A50322)
Kubota 29" Backhoe Bucket (A50774)
Kubota 29" Backhoe...
2011 Ford F450 Bucket Truck (A47384)
2011 Ford F450...
2020 CF Moto 500 Trail (A50514)
2020 CF Moto 500...
2025 Kivel 24in Forks and Frame Mini Skid Steer Attachment (A50322)
2025 Kivel 24in...
KJ 7'x20' Metal Gate (Deer) (A50121)
KJ 7'x20' Metal...
