Rhino finish mowers?
   / Rhino finish mowers? #1
IMCA38
SE Nebraska
MF 1225 w/loader, Case 1840 SS, Ransomes 723D mower
I've pretty much made up my mind on a 25hp tractor from a local dealer (used). I kind of had my mind made up to get a First Choice RFM, but the dealer with the tractor sells Rhino and is offering to set me up with a package deal. Is the Rhino unit comparable to the First Choice? Any pros or cons?
Any other suggestions besides these two?
Todd
   / Rhino finish mowers? #2
they've got the best bush hog i'd say it's good befco has good one also.
   / Rhino finish mowers? #3
I would go with the Rhino -- no question about it.
   / Rhino finish mowers? #4
I have a rhino FM60. Great machine with plenty of grease fittings. You won't be disapointed.
   / Rhino finish mowers? #6
All the mowers mentioned will do a fine job. The box frame mower design like the FC, LP, BH & Woods are noted for being more durable. The FM Rhino is a good mower but the Breeze Rhino's are ALL ITG and made in China but seem to be holding up ok. The Breeze models are their Economy line.
Hydraulic 80 mm pin thumb & coupler combo (A52384)
Hydraulic 80 mm...
2005 GMC 8500 (A50123)
2017 CASE IH 580 QUADTRAC ARTICULATING TRACTOR (A51247)
2017 CASE IH 580...
2024 JOHN DEERE CP 770 LOT NUMBER 22 (A53084)
2024 JOHN DEERE CP...
IF YOU BID ON AN ITEM YOU MUST PAY FOR IT!! NO BACKING OUT AFTER IT IS SOLD!! (A50775)
IF YOU BID ON AN...
