Rhino cutter blade replacement
   / Rhino cutter blade replacement #1
chrisjbell
Platinum Member
Sierra Foothills, Northern California
Kubota B7300; JD LX233
I just replaced the blades on my Rhino SE4 rotary cutter. It was definately time - the old ones were pretty worn down. One of the blades went on just fine and after torquing it down as tight as I could with a 3/4" breaker bar and cheater (they are supposed to be torqued to 350 lb/ft but I don't have a torque wrench that'll go anywhere near that tight) it will pivot the way it is supposed to.
The other blade doesn't want to pivot when it is nice and tight. I replaced the bolts, nuts, and washers, all ordered from Rhino and all according to the serial number on my cutter. (There were different configurations for the blades during the production run.)
Has anyone run in to this situation? I figure I can call Rhino and ask them, but not until Monday and I was hoping to do some cutting tomorrow.
I did take it out and run it and it seems to work just fine, but I was careful not to hit anything that would require the blades to pivot. That won't be realistic when I cut the rest of the place (if I could do that, I'd use a finish mower :)).
2012 MERTZ/ S&S BLENDER UNIT (A50854)
2012 MERTZ/ S&S...
2020 MACK PINNACLE (A50854)
2020 MACK PINNACLE...
2007 Mauldin MT-500 T/A Tack Trailer (A49461)
2007 Mauldin...
2007 CAT 904B (A47384)
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50324)
2018 Toro Grounds...
STIHL TS420 CUTQUICK SAW (A50854)
STIHL TS420...
