Reversing Wheels?
   / Reversing Wheels? #1
hbaird
Deadwood Falls Louisiana
Jinma JM200LE
How many have reversed their tractor wheels for greater stability? I have some slopes and would like greater safety. How much wider is the track? What are the disadvantages?
Harold
   / Reversing Wheels? #2
Mine are like they come from northern,,,I bet you I at least equal you as far as hills go,,,just got to know where you can go sideling and where you have to go up and down,,if your carefull,,it will take a pretty steep degree sideling,,,more than my pecker factor can,,I know that,,,,,,others have said that you don't want to increase front width,,might break front end axil??,,,don't know,,,but do know this,,,my 5 ft brush hog and 5 ft tiller,,barly cover tracks on my 254,,if I made rear wider,,they wouldn't,,that is reason enough for me not to...thingy
   / Reversing Wheels? #3
</font><font color="blue" class="small">( How many have reversed their tractor wheels for greater stability? I have some slopes and would like greater safety. How much wider is the track? What are the disadvantages?
Harold )</font>
Hey Harold,
On my little 224, the rear wheels are spread almost as much as possible, but I could make them a little bit wider if I flipped the inner hub plate around. The rear wheels on mine is about right for a 5ft box blade.
What I really wanted to do was, switch the front wheels, but too many told me that it put too much pressure on the front axle on the 4WD. So I didn't do it. I have heard allready too many problems with front ends, and it just wasn't worth the risk to me. However if mine were a 2wd, then I would spread the front wheels out.
Have a nice day,
Joe /forums/images/graemlins/cool.gif
   / Reversing Wheels? #4
I meant to type pucker factor,,,,,not pecker factor,,,,,now pecker factor is a whole new conversation,,,,,pucker factor is,,,well you know.........I really crack me up,,,,the thing
   / Reversing Wheels? #5
I flipped my hubs on the back tires and have them as wide as possible. I don't know for sure how much width you get but I do feel more comfortable on slopes. As Dick said though a 5' tiller will not cover tire tracks.
Mark H
   / Reversing Wheels? #6
I flipped my front wheels, can't see why it should make that much difference to the axle. I can not say I feel any safer because I flipped them from new. I had already browsed this site for advice and at that time things looked in favor of flipping. Flipping your front wheels puts them in line with the rear ones; I kind of like that because that means if I can get through with my nose I can follow through with my rear end. Unfortunately, if you have a FL that is, the bucket is now somewhat on the narrow side. I had my bucket widened to one centimeter more than the tractor width on each side, so now I can clear all before me. Expensive, yes, but I too don't like the feeling that I'm going to topple over. You go for it; my 284 works very hard if the axle was going to break it would have done so by now, I am sure.
   / Reversing Wheels? #7
</font><font color="blue" class="small">( I flipped my front wheels, can't see why it should make that much difference to the axle. .... You go for it; my 284 works very hard if the axle was going to break it would have done so by now, I am sure. )</font>
There is a growing number of 4wd Jinma owners who've repaired/replaced their front drives that may take exception to that advice. Most of them said they were FEL equipped.
Although not clearly expressed - it IS in the owner's manual. In mine at least. Of the entire 200 series, only the JM220 and JM250 front tread width is classified as adjustable (by means of a "step-through extension sleeve housing").
My manual indicates the JM180/184/200/204/224/254 (and by extension the 284) are all categorized as "non-adjustable". Your JM284 was engineered with a 1050mm fixed front wheel width. It's apparent they don't consider reversing the front wheel rims an option either.
That said, the manual is a few years old. If there's someone out there with a newer version............?
//greg//
Sullair 185 (A50123)
2025 K3325 UNUSED Double Garage Steel Barn (A53117)
2025 K3325 UNUSED...
Crane Carrier Co. Low Entry New Way 31ASL 31Yd Side Loader Garbage Truck (A51692)
Crane Carrier Co...
NEW Work Saver Skid Steer/Sub Compact Grapple (A53473)
NEW Work Saver...
2013 Chevrolet Impala Sedan (A51694)
2013 Chevrolet...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
