reversing tires?
   / reversing tires? #1
saiga
meridian, idaho
2005 MF 1533
i know ...very dumb question but can i reverse the tires on teh rear to give me more rear end width? i would leave the valve stem on teh inside but still accessible. anyone?
   / reversing tires? #2
depending on your rims and then your type of tire turf it should not hurt but ag or ind they wont clean if they are running backwards
   / reversing tires? #3
course the tire direction you just switch side to side
sometimes my brain doesnt work at all
   / reversing tires? #4
Old Ford 8-N's had a system where you could reverse rear rims and rim centers to come up with IIRC 8 different positions.
   / reversing tires? #5
Alot of rims are like that IF they are rims for ag tires. If I reverse my JD R4 rims I gain about 3/4 inch. Just enough to put my mind at rest when running chains...
   / reversing tires? #6
My Jinma's tires are able to be set to 4 different widths and then you can reverse the tires by doing what you are saying to give you 4 more options, just like the Ford's the other guy described. My fronts are only able to be switched from side to side giving it a wide or narrow stance.
Chris
   / reversing tires? #7
I set my tires out on my Kubota L4200, I had to unbolt the dish and moved the tires to the outside, it is real wide now, my rear tire width is around 82"'s
   / reversing tires? #8
depending ont he make of the machine and offset of the rim.. yeah.. you can dish the rims out and swap them side to side to keep tread pattern correct..
soundguy
   / reversing tires? #9
My tires were all the way out when I bought my JD 5203 and several people are telling me I need to turn them in. I am confused on matter and wonder what the difference is. My implements are disc harrow, bush hog, box blade, landscape rate and middle buster. Is there any advanatage out or in for these implements?
   / reversing tires? #10
It's more stable all the way out.
But it's a pain if your wheel track is wider than the width of the implement.
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
New Holland 824 2 Row Corn Head (A50774)
New Holland 824 2...
2007 Western Star 4900 SA Tri-Axle Wet Kit Day Cab Truck Tractor (A50323)
2007 Western Star...
2006 John Deere 120C Midi Excavator (A50322)
2006 John Deere...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
2004 FREIGHTLINER CL120 TANDEM AXLE SLEEPER TRUCK (A52577)
2004 FREIGHTLINER...
