Reverse Mowing with LT1050
   / Reverse Mowing with LT1050 #1
stubborn
Bronze Member
Tulalip, Wa (U.S.)
Cub Cadet LT1050
I have had my LT1050 for 2 years now and am quite happy with it overall. This summer I needed to have a relay replaced in the wiring harness because the Reverse Push Button, which allows PTO mowing in reverse, stopped working (it went from intermittent to non-functional within 3 weeks' time).
Is there a way to re-wire the LT1050 so that reverse mowing would be enabled without first turning the key to Reverse and pushing the Reverse button? About 1/3 my mowing (for 5 acres) requires me to back up so it would be handy if I could avoid this process. Are there any owners or service techs who have done this?
   / Reverse Mowing with LT1050 #2
Yep. Crawl under. Work the reverse pedal with your hand. Locate the paddle that pushes in the switch on the reverse pedal linkage. Move the paddle out of the way so it wont come in contact with the switch. Done! Mow in any direction you want, 100% of the time. You may want to drop the deck for easier access under the tractor.
Joel
Hydraulic Cylinders (A49346)
Hydraulic...
2017 Nitro Z 19ft Bass Boat with 26ft T/A Boat Trailer (A48082)
2017 Nitro Z 19ft...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A51242)
KNOW BEFORE YOU...
2010 Ford F-150 4x4 Ext. Cab Pickup Truck (A48081)
2010 Ford F-150...
2006 INTERNATIONAL MA045 DAY CAB (A51219)
2006 INTERNATIONAL...
1996 Monon 45X96 Dry Van Trailer (A51039)
1996 Monon 45X96...
