REVERSE DISCONNECT- how to ?
   / REVERSE DISCONNECT- how to ? #1
ice
se usa
I decided to try to find a way to disconnect the reverse disconnect switch on my RZT50.
The idea is to reduce the wear and tear on the PTO clutch.
I found the switches at the base of the control arms and disconnected them. The base of the control arm has a cam shape to it. When you pull the control arms back, the high area on the control arm base rotates and depresses the cut out switches stopping the blades.
When I took it out in the yard to try it with the switches disconnected, the PTO would not engage.
It must have a chip somewhere that detects the switches or it breaks a complete circuit.
Not sure which.
Does anyone know of a simple way to disable the reverse disconnect?.
   / REVERSE DISCONNECT- how to ? #2
Loosen the upper screw, rotate the brkt down. leave switch plugged in.
Thanks.
I had considered that.
I noticed there are two sets of holes for the switch bracket and figured they were there for a reason.
If loosening and rotating the switch bracket will be enough , that will be even better.
   / REVERSE DISCONNECT- how to ? #4
Thats what I did with mine, totally removed the upper screw, and rotated the brkt down until it hit the frame. And I left it like that. Only have to do 1 side to make it work.
Thanks a bunch for the extra tip about only having to do one side to get the desired results.
As you know, one side is easier to get to.
thanks again
   / REVERSE DISCONNECT- how to ? #6
If you only have to disconnect one side; it sounds like the disconnect happens when BOTH arms are puled back at the same time.
   / REVERSE DISCONNECT- how to ? #7
Right, it only kills the deck when you are going in full reverse (Both lapbars pulled backward)
Reamer74, your instructions for a simple fix were right on. I did what you said and it worked like a charm.
Also, I can put it back to its original state in ten minutes.
2022 Down2Earth 82in x 36ft Two-Car Hauler (A52128)
2022 Down2Earth...
CATERPILLAR D3K2 LGP CRAWLER DOZER (A51242)
CATERPILLAR D3K2...
2020 KUBOTA RTV...
2 Vintage Metal Signs (A48081)
2 Vintage Metal...
2019 CATERPILLAR D6T LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2017 Ford F-550 Ext. Cab Valve Maintenance Truck (A50323)
2017 Ford F-550...
