Rev TEK reverse switch
   / Rev TEK reverse switch #1
whaltiwanger
Lake Murray, SC
Hi all, I currently have an early 90's model Cub 1720 Hydro lawn tractor, and in the market for buying a New 1050 Cub.. The only thing that scares me is the Rev TEK, and Reverse Caution mode switches.. Just what is Rev TEK, how does it work, and the reverse caution mode? My old 1720 Had a switch that I bypassed to mow in reverse. The New one has selection on the key switch and a button you depress to mow in reverse.. Seems kinda aggravating being as i have a lot of trees to mow around. Any information on these two things would be helpful, and if any of you have bypassed these things, how did you do it.. Thank you!
   / Rev TEK reverse switch #2
All it is is an override switch that allows you to mow in revers. It is very simple to operate and it is a welcome new feature. You have to reset it every time you mow but it takes maybe one second to set. I wouldn't let this feature scare me off.
   / Rev TEK reverse switch #3
It's no sweat once you get used to setting it. (I'm still used to the OLD school LT/GT's!!). Once she's started, you rotate the ignition key one click to the left & press the yellow button. A bright LED lights up & you can now mow in reverse all day long. Like Gamble says, if you s/d the tractor, or trip the seat switch, you'll have to remember to to reset the REV TEK again. I still forget to do it 50% of the time. I get reminded REAL quick the first time I mash the reverse pedal.
G/luck
Joel
2011 FORD F-350 SUPER DUTY (A52472)
2011 FORD F-350...
2018 INTERNATIONAL LT625 (A52472)
2018 INTERNATIONAL...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
2018 Ford F-150 Pickup Truck (A51692)
2018 Ford F-150...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR1BJ325796 (A51572)
2011 International...
