Return of the Workmaster
   / Return of the Workmaster #1
dgl24087
Veteran Member
Va/WV
1975 John Deere 1530
From the New Holland web site (wonder if Powermaster will return as well?):
WORKMASTER Tractors Feature Trusted Name and Simple, Dependable Performance at the Right Price
New Holland, PA (October 30, 2009) -
New Holland's new WORKMASTER tractors bear a trusted name, and the same important qualities that made the original WORKMASTER tractors so popular in the 1960s. True to the original models, New Holland's new WORKMASTER tractors are dependable, basic workhorses that are simple to operate and easy on the wallet.
The 45-hp WORKMASTER 45 and 55-hp WORKMASTER 55, which replace New Holland's popular TT45A and TT50A tractors, are powered by proven, fuel-efficient, four-cylinder New Holland engines. The engines are Tier III emissions compliant and can be operated with diesel or B5 biodiesel fuel. They deliver quiet start-ups and smooth, quiet operation.
Just like the originals, the new WORKMASTER tractors are built to work hard and last long. Their strong, cast iron axles effortlessly handle the stress and strain of heavy loader work. Big three-point hitch lift capacity (more than 2,500 lbs. on the WORKMASTER 55) means the tractor can manage larger implements. And for added traction and better performance in tough, slippery conditions, WORKMASTER tractors are available with a front-wheel-drive axle option.
Simple and reliable
With an 8x8 transmission with four constant mesh gears in two ranges, WORKMASTER tractors provide speeds to match any task, from mowing to loader work. Gears are set up in a simple H pattern, and shuttling between forward and reverse is easy. A synchronized mechanical shuttle lever, conveniently located to the left of the steering wheel, makes controlling the loader a cinch.
The comfortable, open operator station is designed for operator convenience with plenty of foot and leg room. Controls are easily accessible right next to the seat, and bright, clear, analog instrument gauges are easy to read. The suspension on the deluxe, contoured seat adjusts for operator comfort. The sloped hood and rounded fenders provides outstanding visibility, another big plus for loader work. And the vertical exhaust directs noise, heat and fumes away from the operator.
New Holland's WORKMASTER tractors are expected to be available at New Holland dealerships in early 2010. MSRP for these tractors starts at approximately $15,600 (C$21,000).​
http://agriculture.newholland.com/u...WORKMASTER-Tractors-Feature-Trusted-Name.aspx
   / Return of the Workmaster #2
There must be a group of people at NH-Fiat who get a raise or extra stock options for every model # change and reinvention :D
Who could possible keep up with what these models really are or how they compare to each other?
Dave.
2001 HEIL PNEUMATIC CEMENT TRAILER (A52576)
2001 HEIL...
2011 International WorkStar 7400 Chassis Truck, VIN # 1HTWGAAR6BJ325793 (A51572)
2011 International...
2014 Ford Taurus AWD Sedan (A51694)
2014 Ford Taurus...
2007 Eager Beaver 35 GLB Lowboy, Tandem Axel (A52384)
2007 Eager Beaver...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
