>>>>RETURN LINE ISSUE ????
   / >>>>RETURN LINE ISSUE ???? #1
BearKiller
I just discovered that the little fuel return-line was just hanging from the tank; I had wondered what it was, just wrapped around the fuel filler-neck, but thought it was just a wire, until just now when I had the hood off.
The little steel "nipple" is missing from the injector return-line assembly, probably broken off.
I probed it's hole/opening with a 1/16 bit and could poke it quite a ways back in there.
The engine runs like a brand-new (all mechanical) Cummins.
I started and ran the tractor (just sitting, no load), and I did not see any fuel dripping/squirting from that opening.
I haven't taken time yet to remove the injector-lines for further inspection.
Shouldn't there be quite a healthy stream of fuel cycling through ??
Some previous owner has installed a compact little 4-PSI electric pump.
How am I gonna fix this ??
Thanks.:cool:
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
2014 GMC Sierra 1500 Crew Cab Pickup Truck (A51692)
2014 GMC Sierra...
METAL FILING CABINET (A53843)
METAL FILING...
2011 Manac 36245B30 43ft T/A Walking Floor Trailer (A50322)
2011 Manac...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
