Retrofit spin on hydraulic filter?
   / Retrofit spin on hydraulic filter? #1
Anonymous Poster
Epic Contributor
Is it possible to retrofit a spin on hydraulic filter to tractors that only came with the screen filter? Is it worthwhile?
   / Retrofit spin on hydraulic filter? #2
It sure is possible
Northern hydraulics sells a kit with filter to do it.
I put one on my wood spliter It was easy plumbing too.
just make sure that the filter has enough volume to handle
the demand, you install it on the return line (the 1" line)
It worked for me!
Ern. <><
   / Retrofit spin on hydraulic filter? #3
If you use hose to make the connections, it is actually 7/8". I had to order 3' just to get a 4" piece to repair the original hose that leaked.
   / Retrofit spin on hydraulic filter? #4
Use a Spin on screen instead of a spin on media filter. Less cavitation and your pump will live longer.
2023 FORD TRANSIT VAN (A52576)
2023 FORD TRANSIT...
2011 TROXELL 130BBL (A52472)
2011 TROXELL...
CATERPILLAR IT28G (A52472)
CATERPILLAR IT28G...
New Long Forks (A53002)
New Long Forks...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
