Restoring 8N
/ Restoring 8N #1
goosecreek
John Deere 3220
I am just starting to restore a very rusted 8n. The first problem is that the rear axle is locked up, at least for one wheel. Any ideas on how to free it up?
/ Restoring 8N #2
so.. with the rear jacked up, and trans in neutral, only one wheel spins, and the other is solidly locked?
if so.. I'd be that sides axle to see if it seized to the bearing, and/or the left trumpet to check the diffy / spiders..
post back.
ps.. you have checked the brakes on that side right? to make sure they are not hung up / locked down??
soundguy
/ Restoring 8N #3
The brake is rusted to the drum. back the adjuster all the way out if possible and usually a few good whacks with a hammer against the face of the drum will unstick them. Obviously you'll need to remove the wheel first.
2016 Peterbilt 579 Day Cab w Hydra Flow Setup (A62613)
2016 Peterbilt 579...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2022 John Deere 325G Track Loader (A63111)
2022 John Deere...
2017 FORD F-350 XL 35' NON-INSULATED BUCKET TRK (A59823)
2017 FORD F-350 XL...
2015 FREIGHTLINER CASCADIA 125 6X4 T/A GLIDER SLEEPER TRUCK TRACTOR (A59911)
2015 FREIGHTLINER...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
