resistance testing on H5013
   / resistance testing on H5013 #1
thebda
I have a Honda 5013 tractor that won't start and my friend and I were starting to look at the CDI ignition coil and cdi unit and exciting and pulser coil and charging coil ad outline in the service manual. We noted that there was no defined range to set the ohmmeter to for some of this testing AND are trying to determine what ohmmeter would be equivalent to the listed Digital Volt-Ohmmeter-No. KS-AHM-32-003. We would greatly appreciate some direction on this OR at the very least your recommendation for what the problem probably is. Thank you!
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXELL 150...
Mobile Transformer and Power Substation Portable Power Supply (A55218)
Mobile Transformer...
2014 Ford Fusion SE Sedan (A53424)
2014 Ford Fusion...
2016 FORD F550 SUPER DUTY SERVICE TRUCK (A51406)
2016 FORD F550...
2017 KUBOTA SVL75-2 SKID STEER (A52705)
2017 KUBOTA...
2009 PARKER 25 T/A GOOSENECK TRAILER (A52472)
2009 PARKER 25 T/A...
