Resharpening chainsaw chains.....how many times?
   / Resharpening chainsaw chains.....how many times? #1
TNhobbyfarmer
Veteran Member
Middle Tennessee
Kubota L3430 Polaris Ranger 500
I have resharpened the chain on my chainsaw several times. It seems to be getting dull more quickly these days. Is there a rule of thumb about how many times one should be resharpened before it needs to be retired?
   / Resharpening chainsaw chains.....how many times? #2
Hi TN,
Most chains have a line etched in the teeth to let you know when you've filed them all thats recommended.
I think its around 1/8 inch... look on your chain for the line.
   / Resharpening chainsaw chains.....how many times? #3
Since time=money, I use this rule. I am currently rotating 7 chains on my 18" chainsaw while clearing 2.5 acres. I am cutting stumps about 1" below ground level. Needless to say, I am hitting a lot of hidden rocks and damaging chains. When the sharpened chain starts throwing "dust" (pieces of wood that are not thin, flat and look like like obvious shavings) within 3 minutes of cutting, then I throw it away. There is probably a precise scientific answer for this question involving wear on the chain measured precisely. I merely look at my right boot and when I see dust being thrown right after sharpening, it is time to junk the chain. A new chain will cut super fast until dulled by a rock, metal or lots of use. It can be resharpened about 5-8 times at a cost of $3-4 per sharpening. If you ever feel yourself pushing the chain bar down or trying to work the bar back and forth like a hacksaw, you have exceeded the chain usefulness. Put a new/resharpened chain on and keep going. You should NEVER have to force a chainsaw blade at all. Not up, down, sideways or any way. Forcing one is bad news. A dull blade needs to be sharpened. You are wasting your time trying to cut with a blade that is not throwing chips of wood that are flat, thin and look like shavings.
Make sure to have gloves or a rag ready. Bars and blades get HOT!!! I usually take a 2-3 minute break between chain changes. The bar will still be very hot after 3 minutes.
   / Resharpening chainsaw chains.....how many times? #4
Guys, I've read many sharpening posts before and tried my hand at it rather unsuccessfuly(its actually time consuming to do it right), and have heard many recomend against the electric sharpeners for a good sharp chain.. I have also posted (http://http://www.rapcoindustries.com/ ) this link before since I purchased one a few months ago.. This chain cost about $150, but since using it on about a chord and a half of hardwood, I dont regret it a bit and will be buying another down the road.. No need to sharpen it, honestly I'm not sure you could.. The guy that sold it to me said he had used one to cut roots 6" in the ground(in the dirt) before and didnt loose the edge(surely it effected the bar).. These chains are also made for demolition and cutting creosote poles and tin among other stuff... Just a thought for those of you who feel "time is money" like me...
   / Resharpening chainsaw chains.....how many times? #5
You can resharpen the chain as long as there is enought top plate left on the cutter. You have to file down the depth guage on the cutter as the top plate gets smaller. Check the Oregon site for some good information on the subject.
http://www.oregonchain.com/tech/ms_manual/ms_02.pdf
I purchased one of the Harbor Frieght electric sharpeners and it works great, once you set it up it goes fast, it holds all the correct angles. My chains are sharper than new and really are holding an edge. You want to make sure you only remove enought material to get a new edge on the cutter and check your depth guage height and you are ready to go.
   / Resharpening chainsaw chains.....how many times? #6
Sharpening chains SHOULD ideally be done on a machine, that way it keeps the teeth all the same size. Hand sharpening and those 12 volt electric sharpeners leave the teeth uneven. THEN, when you take it to a sawshop, they have to sharpen to the smallest tooth!
I have my own sharpening machine, they don't cost too much, but are well worth the expense.
Always keep a couple of spare chains when out cutting wood.
   / Resharpening chainsaw chains.....how many times? #7
I have dedicated chains. New chains/sharpen once or twice are reserved for cutting larger material, up to 24" oak. Chains that have been through the mill so to speak are used for small stuff, up to 10". Then the old streached, sharpen chains are saved for cutting roots/stumps. As you might imagine, these chains don't have much tooth left.
I use the dremal free hand. Sharpen very lightly before tightening the chain. With the chain loose she slides nicely. With pratice, you will have a pile of sharp chains for everey job.
Dull chains kill chain saws and make you work much to hard!
   / Resharpening chainsaw chains.....how many times? #8
I would have to agree I use the machine and love it. Sure some claim it shortens the chain life. but If you remove just enough to make it sharp thats all thats required.If your interested there are many more opinions at this site.
http://www.forestryforum.com/
I use mine untill there isn't any metal left to sharpen. Usually use them for stumps etc when they get over 3/4 of use.
Ive had them sharpened on the expensive machines, but the HF one is a great buy for the homeowner with occasional use.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=93213
I pain about 99 dollars for mine three years ago. now they can be had for under 30 dollars:( for me:) :D for anyone buying now
   / Resharpening chainsaw chains.....how many times? #9
Just remember that running a dull chain will get it hot and it loses some of it's temper. After this they just don't hold an edge as long.
   / Resharpening chainsaw chains.....how many times? #10
Exactly. And I'm not sure a chain has to be that dull to get overheated.
Once a chain gets hot, it will never really be sharp again IMHO. It can get hot because it is dull, or if you push it too hard for too long even a sharp chain can get hot. I've learned to pull it out of the tree and give it a few seconds of spinning to cool off after intense work.
My chains last a lot longer now, and I've tried various sharpening methods for older chains - but nothing will make an old chain cut like new and I generally find that after a few resharpens it's worth the $20 to install a new chain.
2015 John Deere 1200A Bunker Rake (A42745)
2015 John Deere...
2015 Ford F-750 Stellar 10628 5,500LB Crane Service Truck (A44571)
2015 Ford F-750...
1995 International 4700 Truck, VIN # 1HTSCAAN8SH668443 (A44391)
1995 International...
20 Monitors and 3 TV's (A42745)
20 Monitors and 3...
2019 6105E John Deere 2WD Cab 105HP Tractor (A44789)
2019 6105E John...
1991 TOYOTA LAND CRUISER FJ80 (A45046)
1991 TOYOTA LAND...
