Reseeding a First Year Alfalfa filed
   / Reseeding a First Year Alfalfa filed #1
bobm6996
Greenfield, Indiana
Mahindra 5010 4WD HST Cab, Mahindra 2615 Gear, Scag Tiger Cat 48", Gravely 42" ZTR, EZ GO Gas Golf Cart
Have a 12 acre field that was no till drill seeded in the spring with oats, alfalfa and grasses. We have cut and baled the oats off and in the next week or so will be cutting and baling the field. There are a few areas where the alfalfa is pretty scarce and I want to reseed this fall to try and fill. I created a post about a month ago asking for ideas on how to do this and one suggestion seemed like a good approach, use a slit seeder. I have been trying to find a rental place with no luck in the Indianapolis area, plan to keep calling around.
If this search continues to be difficult would it be possible to just use a drill? I have a friend who has a 10 ft. drill that he has told me I could use if ever needed. I would not be able to till the ground, so just curious if I could do this?
   / Reseeding a First Year Alfalfa filed #2
Last I checked seed was expensive.
Drill is gonna blow throw seed quick.
SOGOTP. Do U want grass or alfalfa?????
Make up ur mind and check back, Cheers, JoeB
   / Reseeding a First Year Alfalfa filed #3
I'd lightly disc the bare spots in the field and then plant alfalfa using a grain drill with a grass seed box that can handle the tiny alfalfa seeds. You can drag a chain behind the drill to cover the seed and or use a roller to press the seed into contact with the soil (very important to get efficient germination). I don't think a regular grain drill would work well in untilled soil so I wouldn't waste seed on that approach.
You also need to consider that alfalfa is auto-toxic, i.e the established plants will kill newly germinated seedlings. That may not be a problem in your thin areas.
Good luck.
2015 Chevrolet Silverado 1500 Pickup Truck (A50323)
2015 Chevrolet...
(10) 28' Continuous Fencing Panels (A50515)
(10) 28'...
1999 Ford F450 Dump / Plow Truck (A50514)
1999 Ford F450...
2018 Chevrolet Malibu Sedan (A50324)
2018 Chevrolet...
(2) Oliver Wheel Weights (A50515)
(2) Oliver Wheel...
KJ 20'x30' Metal Garage (A50121)
KJ 20'x30' Metal...
