Researching a mid mount mower deck
   / Researching a mid mount mower deck #1
BBhuey99
GC2200
New user here guys.
I have a 2011 GC2200. It's been a great little tractor and plenty for what I need it for. My question is I have 10 acres that I mow with a 5ft bush hog. I'm interested in a mid mower deck since the hog tends to not cut some of the lighter stuff we'll and requires me to do a reverse path on each pass to get everything properly cut.
Do you agree that a mid deck is better for a more manicured cut and if so, which deck model/size would you suggest for my little diesel?
   / Researching a mid mount mower deck #2
I don't recommend a mid-mount mower. Mine sits unused for 20 years. PITA to mount & dismount, not so great in corners. Can be difficult to trailer because the deck clips the ramps at the edge of the trailer. Harder to access the blades for sharpening or change out. Instead a 6' or 7' rear finish mower works for me. But you run over the grass, then cut it.
Better is a separate front mount deck. I have a JD 1435 with the 7 Iron side discharge front mount and also an F-935 with a front mount rear discharge deck. Best looking cut comes from the front deck because you cut, THEN run over the cut grass.
   / Researching a mid mount mower deck #3
Back in 2014 when I was looking for a loader tractor, I decided it had to fit all my needs since I was only going to buy one. I bought my Mahindra 3616 hst 4wd with loader and a 72 inch belly mower. Man was I happy when it got delivered. But over the first summer I realized some things. This thing mowed a beautiful lawn for sure. But I soon found that the engineering of belly mowers on tractors is just missing some things. Even with the deck pinned up, ground clearance was terrible. There were many days I found myself removing the deck for loader work and installing for mowing twice in a day. I thought it would be utopia to pin up the deck and run a 3 point implement, but again ground clearance.... Then one day my buddy bought a zt mower. I immediately regretted trying to have one machine that would fit all my needs. I need to clean barns, move bales, rake, till, and mow grass. And use the loader. My 72 in. MMM sits in machine row, propped up on blocks and hasn't been used since 2014. I have put it on a couple times just to remember the install sequence and mow a strip or two to keep it turning. But I have used my tractor for tractor things and mow with a zt mower. I'm not even sure what the MMM option cost originally, but it was not a worthy purchase for me.
   / Researching a mid mount mower deck #4
I use my mid mount all mowing season and like it. Mine goes on and off pretty easily, less than 5 minutes. Unless you have narrow areas get the widest you can. Usually a mid mount is specific to your tractor brand and others won’t work easily.
   / Researching a mid mount mower deck #5
There are advantages and disadvantages to both mid-mount and pull behind mower decks. The front mount is very versatile but the rear discharge puts the cuttings in the air in front of me. Grandpa had a Farmall Cub that had gang reel mowers mid-mounted and it mowed nicer than anything else. But the yard needed to be pool table flat and the reels only wanted to cut about an inch off the grass. My brother has the family place in Ohio and he sometimes pulls gang reel mowers behind the little New Holland diesel with a 60" mid-mount deck, showoff!
We moved to 3 acre place in Texas finally closing escrow late in 2021. I brought 4 of my Wheel Horse garden tractors with us in the move and I figured we could get a couple of 48" mid-mount decks to handle the mowing for awhile until we found something else. It was tough buying a house here near Dallas in 2021 and I think 9 places fell out of escrow due to something wrong with the house ao we were homeless and living in a Residence Inn in Lewisville, TX my wife and I and the 2 dogs. I found a Massey Ferguson like my 2008 GC2410 TLB in Corsicana, TX about a 100 miles away. I wanted to look at the tractor since the 2410 was the best power wheel barrel ever. I told my wife that we were not going to buy a tractor we just needed to get an idea of what we wanted to consider. And we literally had nothing to do on a weekend so we loaded up the dogs and headed to the Massey Dealer. My wife is a city girl but she loves to mow when we went back to Ohio every year for my mom's birthday in May. There is about 5 acres left in Ohio but she would mow probably 15 or more acres mostly with a Farmall Cub with a sickle bar mower. She also mowed around the house with the New Holland. But she has allergies and would end each day with sinus' stuffed up and puffy eyes. But she would not stop! I knew that the dealer had a 35 horsepower Massey with a air conditioned cab in stock and that would give use some ideas. No intention of buying during a big supply chain shortage. We got to the dealer and I introduced Jacquie to the dealer Al. I walked the dogs and Al showed Jacquie the 1800M series tractor, I did not know that Al got a 1840M in the day before with a deluxe cab. LED work lights front and rear, pull down windshield sun shade, bluetooth radio, rear window defogger, and a air ride seat as well as a cabin air filter for the Air Conditioning. I was walking the dogs in the back lot and along comes Jacquie with the 1840M with the biggest smile on her face you have ever seen. By the time I got up to the office the first thing I heard was Jacquie saying we can't buy the tractor today but would a $ 1000 deposit hold the tractor until our escrow closed in a week or so. The next thing out of Jacquie's mouth was would 5 be better, Al said $ 500 was more than enough but Jacquie said $ 5000. Before I could open my mouth she had a check for $ 5K in the smooth southern gentleman's hand. So from just looking to now I need to decide what attachments for the tractor. I knew I wanted a loader with a skid steer quick connect 72" bucket and a 72" mid-mount mower, both scheduled for delivery in September 2022. I also saw a 7' landscape rake that had a pair of wheels behind the tines, a 72" box blade and a set of pallet forks. The loader and mower deck not being available until September was not good.
The tractor and I think the landscape rake were delivered just before Christmas 2021. I told my wife that the tractor was hers and I would not even drive it. My oldest daughter came down from OKC to visit and help unpack when the tractor was delivered. Those 2 decided that the tractor was named Mator from Disney Cars. I was lucky and found a used 3 point Land Pride Air Tunnel 72" finish deck for sale and bought it. Keep the ideal that the tractor belongs to my wife in your head since that was a real men of genius moment since I can't use her tractor I don't need to mow! The german shepherd loves to ride in the cab of Mator and keeps Jacquie company, in fact I think he believes it is his tractor. Of course I'm stuck doing the trimming with the Wheel Horse. Fine trimming is done once a year with Groundclear, I love chemical weed eaters.
Now for the unintended consequences of Mator. First I have lost 25% of my workshop and 1 roll up door. I have a 30 x 40 foot workshop but Jacquie has acquired a big chunk of floor space and my 48" Gladiator cabinet as well as my new 6' Husky workbench got moved from my side to hers. This occurred when our youngest daughter was visiting. Maybe 5 or 6 years ago one of our neighbors in Ohio was selling all his Farmall tractors and he had a 1952 Cub in really good condition for sale so my brother picked it up for Jacquie. It's name is Cubby. We drove up to Ohio in May 2022 for mom's 95th birthday and brought Cubby to Texas. My brother gave Jacquie a very nice Matco tall tool box that was missing the wheels. I had 2 sets of hand tools my good S&K set and a Costco set from Taiwan. So she got the Costco set. The Gladiator cabinet got full so she needed cabinet # 2. She also has her 2 Farmall stools in the living room area of my workshop. I still have the TV for now.
But the comparison between the mid-mount and 3-point finish mowers. In the spring when the grass is growing very fast the Land Pride mower deck has a faster blade tip speed and since it is behind the tractor tractor all the chafe is behind the tractor. When we mow with the mid-mount some of the chafe ends up in the AC condenser and radiator screens. The tractor coolant has never gotten above normal but the AC has stopped working. If the AC stops working so does my wife. I don't know if the mid-mount will cause airflow issues with your tractor. I have learned how to easily change the mid-mount deck, turn the 4 mower wheels sideways, use 2 high lift floor jacks to raise up the front axle of Mator, roll the deck under from right to left, let the front of the tractor down and hook up the lift/mounting bars, pickup the deck and from behind attach the 2000 RPM PTO shaft. I don't know if the GC2200 has a drive over mid-mount. We talked about a mid-mount for my GC2410TLB but we could put the 60" mower deck on furniture dollies and use the loader and backhoe to lift the tractor. Another big consideration for a 3-point finish mower is that it will work on another tractor, the mid-mount is likely only for the model tractor you buy it to fit.
Long story but the moral is buy your wife a nice mower tractor and let her use it. A zero turn is not an option for us because of no Air Conditioning but you can get a air ride seat and it really mows. I know you can get a 72" zero turn but a bigger deck or decks (batwing) would be great if you needed to mow 10 acres.
Bruce
   / Researching a mid mount mower deck #6
I've a 60 inch that goes under my tym. Used it for 5 years. Never satisfied that lawn was well cut. And 3 acres took a while. Bought a ztr, this is 2nd full year. Love it. Way better cut and 2x faster
   / Researching a mid mount mower deck #7
New user here guys.
Having to double-cut each swath means one of 2 things, blades are dull or ground speed too fast, or both at the same time.
I have a 6' Woods rotary cutter, if I keep the blades sharp and use the correct gear, my former pasture-land looks like my lawn, just mowed higher.
   / Researching a mid mount mower deck #8
I have mid mount and yes it would be better. I think some guys say its a pain in the ass to mount b/c they are pulling back on the mechanism when connecting to the pto shaft. You dont need to do that. You simply line up the teeth and it will slide right on. Once it has slide on then you pull back on the locking mechanism and slide it the rest of the way on. Then pull back on it to make sure its on
   / Researching a mid mount mower deck #9
On a SCUT or small compact, the MMM is by far the best way to go. We had one on Dad's 1523, absolutely loved it.
2020 Ford Escape SE SUV (A42744)
2020 Ford Escape...
2011 BMW 528i Sedan (A42744)
2011 BMW 528i...
2020 POLARIS PRO XD (A45046)
2020 POLARIS PRO...
Kubota L4630 GSTC (A42021)
Kubota L4630 GSTC...
2018 INTERNATIONAL RH613 DAY CAB (A45046)
2018 INTERNATIONAL...
LIVESTOCK SHED GALVANIZED METAL (A45046)
LIVESTOCK SHED...
