Research: Hydraulic steering
   / Research: Hydraulic steering #1
Kaliburz
West
JD 60, 3020, 2030, 2240, 2640, Farmall A
Hello folks.....doing a little research for a potential project. Let me give a little background....
Equipment: CLARK forklift
Year: late 60's to mid 70's model.
Problem: Original steering box broke. Replacement box found is "reversed"....you turn the steering wheel left, it makes you go right. Any how, if I recall, it is power steering already...not sure if it has a slave cylinder or if it's built into the steering box.
Hydraulics: I believe it is an open center system.
I was thinking of removing the steering box completely and going with a Char-Lynn steering steering valve from Surplus Center. To actuate the system, either add a hydraulic cylinder or use the existing one (if there is, haven't looked in a while, equipment belongs to a buddy). I'm sure there is enough steel down under the forklift the other end of the steering cylinder could be mounted to (or a bracket fabricated & welded/bolted in).
Any how, I have no idea how to choose which steering valve to choose. I've heard some valves allow you to steer w/out power, when moving the equipment, while some do not. Not sure how that would be listed or what it is called. There is quite a bit listed on Surplus Center for steering valves.
Thanks ahead of time.
UNUSED WOLVERINE TQH-26-02C CLASS 1 QUICK HITCH (A54757)
UNUSED WOLVERINE...
2016 FREIGHTLINER CASCADIA DAY CAB (A54607)
2016 FREIGHTLINER...
6 Yard Commercial Dumpster (A51692)
6 Yard Commercial...
2006 CHEVROLET EXPRESS SERVICE VAN (A54313)
2006 CHEVROLET...
2018 Bobcat T590 Two Speed Compact Track Loader Skid Steer (A55787)
2018 Bobcat T590...
2025 JMR 40in Single Cylinder Grapple Skid Steer Attachment (A55787)
2025 JMR 40in...
