Rerrir Code 50-67
   / Rerrir Code 50-67 #1
Tlysflys
Kubotta M5040
When using my tree-shear, the general warning light came on. The Toolcat (2011 F-Series) will not move forward or backwards. The error code I was able to retrieve (it first said NONE) is 50-67 "Servo Coil under Current". After the machine sits for a while, it will work again and then the light will come on again and the cycle repeats. Any advise?
   / Rerrir Code 50-67
Meant to say Error Code, sorry.
   / Rerrir Code 50-67 #3
If it starts to occur more frequently have dealer do a software update. If I remember correctly bobcat released an update to force controller to wait a little longer to verify communication with this coil. I think the update was released later part of 2015 or very early 2016.
I have retired from bobcat so can no longer get into system to look it up and be certain on this.
   / Rerrir Code 50-67
Thanks Dennis - it started doing it every time I use the Toolcat. Also, it appears that it occurs when in reverse. I will bring the Toolcat to the dealer and ask him to update the software. However, do you know why this issue would have started just recently - I had the Toolcat for three years and it never occurred before.
Again, thank you for your input and enjoy your retirement.
TL
YARD MACHINES MOWER (A50854)
YARD MACHINES...
1972 Ford F600 Grain Truck (A51039)
1972 Ford F600...
2002 NEW HOLLAND 4X4 TN75S TRACTOR (A51243)
2002 NEW HOLLAND...
1995 FORD LT9000 DUMP TRUCK (A51222)
1995 FORD LT9000...
2011 GROVE TMS900E TRUCK CRANE (A50854)
2011 GROVE TMS900E...
2015 Hamm H7i VR-3 Single Drum Vibratory Soil Compactor (A49346)
2015 Hamm H7i VR-3...
