Repowering White 2-70 with Cummins Diesel Engine
   / Repowering White 2-70 with Cummins Diesel Engine #1
1989 Ford 260-C 4X4 industrial
Anyone know where to get a conversion kit and engine to re-power my broken crankshaft 2-70 White ?
   / Repowering White 2-70 with Cummins Diesel Engine #2
If it uses a universal bell housing it should change out. But, white is pretty old. You may have to make a bell housing adapter. Whatever thickness it is, space the flywheel same amount. Bell housing adapters are on many trucks. I have used them and taken some off. Seems all old GM trucks had them. Every one I ever taken apart had an adapter. Ford I have only seen them with the 300 six in F600 trucks.
   / Repowering White 2-70 with Cummins Diesel Engine #3
Late replay but Call Maibach Tractor in Ohio. 330-939-4192 They may have something.
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
2013 Ford F-150 4x4 Pickup Truck (A51692)
2013 Ford F-150...
2010 Hyundai Elantra Touring Sedan (A51694)
2010 Hyundai...
NEW 2024 LOAD TRAIL 83IN X 14FT Tandem Axle Dump Low-pro Trailer (A53473)
NEW 2024 LOAD...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
