repowering skid steer
   / repowering skid steer #1
anesthes
Bronze Member
Salem, NH
Mahindra eMax 22
I've got an old (1974 or so) Erickson CL340 skid steer. 30HP with Wisconsin VH4D engine.
I'm thinking of repowerining with a chonda 22hp v-twin engine.
I had some questions. First of all, how do you guys feel about repowering a tired 30hp with a new 22hp ?
Second was, my machine has a foot throttle. I was thinking of instead just using the governor on the 22hp and keeping it at like 2600-2800 RPM.
I found that some units appear to have been offered without a foot throttle:
Ford CL-30 Skid Steer Loader - Page 1 [#867170 / 867170]
So I suspect it was an option?
Opionions ?
I don't exactly have the specs on the pump for my machine.
-- Joe
   / repowering skid steer #2
An old Wisconsin is a much better engine than any new air cooled out there. You would be better off to have a local shop hone the block out and put in new rings, pistons, and bearings.
I actually have two of these VH4D engines if you are interested. I put them on craigslist but nobody wants them. Both run. Probably end up getting scrap value in a few weeks.
I like the newer engines. They don't overheat at low RPM, have oil coolers, better ignitions, better charging circuits and weigh 1/3 what the old wisconsin does. Technology :)
-- Joe
   / repowering skid steer #4
Suppose you change the rear a little and put in a liquid cooled engine?
   / repowering skid steer #5
I would wonder about actual HP rating. Wisconsin was probably under rated, and the Chonda over rated.
In terms of percentages, your are 25% less, which I think is pretty significant.
   / repowering skid steer #6
The Wisconsin probably has at least twice the torque of the Chonda. I would agree with Mendonsy. Additionally you won't have any conversion issues. Good Luck.
SimS
Perhaps. I found the specs on the pump last night. So it's got 3 outlets, with 15GPH each. One for the FEL, and one for each drive motor.
The FEL has a 1700psi relief, while the drive motors are 1500psi relief each.
I'm assuming the motor was sized based on two of the three circuits in full use at the same time, rather than all three at 45GPM. (which would require 49hp). Assuming 30gpm total at a running pressure of about 1600psi comes in at 26hp.
Regarding retrofitting different engines, that's pretty straightforward. 4 bolts to a flat motor plate, and 4 bolts to a hydraulic pump mount. Most any modern engine has multiple bolt patterns for pump mounts, and even differences in shaft size is easily dealt with using couplers. I'm not too concerned with physically mounting the engine and generating hydraulic pressure. Where I'm looking for advice is the HP difference vs my pump specs, and the thought of a static RPM vs the foot throttle. I could make the foot throttle work by replacing linkage with a cable but I'm curious if I could go without it.
I may end up having to go with a 26-28hp suburu/robin engine if the chonda doesn't make enough power. Though I'm considering what exactly the issue would be if the motor was slightly under powered. Normally I lose traction before I labor the engine pulling, and the hydraulics can lift way more weight than the machine can possibly handle without tipping over anyway.
-- Joe
   / repowering skid steer #8
-- Joe
I'm looking for a VH4D for my skidsteer..
Well if you feel like driving to NH sometime, I've got one that runs, and another that had low compression. Package deal $500.
   / repowering skid steer #10
I'm interested, as long as the end of the crankshaft is the same.. Can you send me a picture of it, when you get a chance.. justme23005 at yahoo dot com
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
2024 FORD F-550 SERVICE TRUCK W/CRANE (A52472)
2024 FORD F-550...
2006 JLG 460SJ Man Lift (A51573)
2006 JLG 460SJ Man...
2018 CATERPILLAR 279D SKID STEER (A51246)
2018 CATERPILLAR...
2013 CAT 950K WHEEL LOADER (A52472)
2013 CAT 950K...
