Repower Gravely 16g
   / Repower Gravely 16g #1
hawkmt
Kempton, PA
John Deer 650, Gravely 16G Professional
Anyone have suggestions on the best way to re-power a 16G? Are there alternative engines to the Kohler Magnum that will fit?
Obviously buying a new engine is not practical, need to do this for $500 or under.
Thanks in advance.
   / Repower Gravely 16g #2
What happened to the Kohler? Is it repairable?
I powered mine (had NO engine when I bought it) with an Onan B48, but it opens up a can of worms what with needing an Onan adapter plate, redoing the exhaust and controls...it could get more costly than a rebuild, depending on your circumstances.
Lots of folks are using Honda GX engines to repower as well.
In reality, any engine with a 1.125" shaft will work.
Hope that helps some,
T
I suppose the Kohler is repairable, but not sure that is the best path. The left Cylinder connecting rod broke, which in turn bent the crankshaft. A total rebuild is quite expensive. This is an old tractor, though being a gravely I want to save it. I have located a $300 used B&S from a 16G...I'm going to do the rebuild with that. But the Onan and Honda information is exactly what I was looking for.
   / Repower Gravely 16g #4
So far on two of my commercial mowers I went with a Kawasaki engine. Never had an issue and they have plenty of shaft diameter options available. Pulled a 22 HP Kohler and dropped a 27 HP Kaw, Z mower go go go now.
2003 Big Tex 10PI 16ft. T/A Pipe Top Utility Trailer (A52377)
2003 Big Tex 10PI...
2022 NEW HOLLAND 266BMM 66-INCH BELLY MOUNT FINISHING MOWER WITH SIDE DISCHARGE (A53473)
2022 NEW HOLLAND...
78'' skid steer bucket (A53421)
78'' skid steer...
13 Frames (A51695)
13 Frames (A51695)
2025 380 Mini Track Loader Stand-On Skid Steer (A53421)
2025 380 Mini...
2007 Godwin Pumps GHP45KW-RC 45kW Towable Diesel Generator (A53421)
2007 Godwin Pumps...
