Report on TC18
   / Report on TC18 #1
Anonymous Poster
Epic Contributor
First report at 15 hours. I mentioned some of these things in the "Buying/Pricing" forum, but they more properly belong here.
Tractor was delivered late Thursday and used for ~1 hour to confirm everything was working. Friday, switched from rotary cutter to box blade, experimented with different settings for the scarifier teeth. Florida soil is very sandy, no problem pulling 4' box blade with teeth all the way down, until encountering a substantial root, when things come to a halt. I suspect that even a bigger compact tractor would have difficulty. Found that best position for flattening the surface and dragging out the wild grape vines was up one step on the teeth. About 3 hours of playing.
Saturday was the first big day. My subcontractor brought in his big Cat loader with brush rake and started moving some previous piles of brush to burn piles, shaking off dirt. We set up 5 big piles. First, I used box blade to clear a spot. As he moved big stuff, I dragged the small stuff with the box blade, gettting a first cut at the grading in the process. I started learning how to use the thing. When the box blade got hung up, I could back off and use the loader bucket to break up the mess, then get back to work with the box blade.
I also tended several of the burn piles - one started to spread, so I knocked down some brush and dumped some dirt on it - a "wild fire" of about 30' spread was out in about 2 minutes. Oh - before someone asks - we had a Div. of Forestry ranger inspect the property and advise us on burning, obtained a "landowner number" and got a permit before burning. Now, all we have to do is call in and advise them on the mornings we will be burning. If conditions are bad, they will advise us each day. Also, my son-in-law is a volunteer fireman and has lots of brush fire experience.
About 11 hours straight. Here's what I've learned. A tooth bar on the bucket is absolutely needed for my conditions. The 4' box blade, 4' rotary cutter (Rhino SE4) and 12 LA loader with 48" HD bucket are well matched to the TC18. Changing the 3PH attachments is a pain in the butt, but with my son-in-law there to help, not so bad that I'm going to look at any quick hitch stuff right now. I will be ordering the new ATI loader quick attach setup very quickly. I need a loader brush rake, but everything available is too heavy, even for a larger compact tractor. We've already started designing a light weight brush rake and will start building it in the next couple of days. If it doesn't fold up on itself the first time we use it /forums/images/graemlins/crazy.gif I'll post some pictures. The ATI setup will make it easier to switch. I'm also going to build one of the root scoop thingies I've seen on some of the forums.
Problems - the power steering is not working when I turn left. Dealer will be called tomoroow. There were two hydraulic leaks where the lines hook up to the joy stick - I tightened those - dealer should have caught that on prep, but since the plastic cover has to be removed, I can sorta forgive it. I got the Industrial tires, and that may have been a mistake - I can spin the wheels pretty easy in the Florida sand. I never got stuck, but I did learn how to use the differential lock very quickly. The delivery guy said the tires are filled (with water - we don't have to worry about freezing), but if they are, it would be impossible to use if they weren't.
I'm going to have to buy a 3PH landscape rake to finish up the clearing - gathering all the sticks and twigs, etc., without pulling as much dirt along as the box blade.
All in all, I'm very pleased. It's hard for a city guy who has never even been within 100' of a tractor before to make the right choice. My thanks to all of the folks here who have been so helpful. Sure, more tractor would be nice, but this one will do what I ask of it, especially once I learn the limitations and how to cope with them.
Sorry, no more pictures, yet. I remembered my camera, but we worked so hard I never got it out of the truck. The land clearing contractor is on the clock, and I didn't want to waste money taking pictures...but, here's one that shows what we are up against (this was after some initial clearing of the vines).
And another that shows a burn pile before it dried out.
It's a jungle out there... /forums/images/graemlins/grin.gif
   / Report on TC18 #2
</font><font color="blue" class="small">( Problems - the power steering is not working when I turn left. )</font>
Could it be air pressure in the tire is low? This happened to me and made it appear the steering wasnt working right. Then I discovered an almost 10 psi difference. It was especially noticable when the bucket was full.
Mark
   / Report on TC18
</font><font color="blue" class="small">( ( Problems - the power steering is not working when I turn left. ))</font>
</font><font color="blue" class="small">( Could it be air pressure in the tire is low? This happened to me and made it appear the steering wasnt working right. Then I discovered an almost 10 psi difference. It was especially noticable when the bucket was full.)</font>
Could be. I so new to all this I can't rule anything out. But, this seems to be a little more than that - turning to the right, you can spin the steering wheel with one finger. Turning to the left, takes two hands and a lot of grunt, like trying to steeer your car with the engine off.
My guess, without having looked at it, is there are two different hydraulic circuits for left and right, and one of them isn't working at all.
   / Report on TC18 #4
</font><font color="blue" class="small">( Turning to the left, takes two hands )</font>
It DEFINITELY was not THAT bad with low pressure /forums/images/graemlins/confused.gif
Mark
2014 Nissan Rogue Select (A51694)
2014 Nissan Rogue...
1982 LeeBoy Motor Grader (A52748)
1982 LeeBoy Motor...
2014 Ford Escape (A50324)
2014 Ford Escape...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2019 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2019 PETERBILT 567...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
