replacing the bushings and pins on my TLB
   / replacing the bushings and pins on my TLB #1
chuck1764
SE Indiana
Yanmar 1700 1975 ford 3550 TLB
I will be replacing the bushings and pins in my backhoe and i need to know what steel to use for my pins and if i will need to heat treat them? The bushing will be 2in DOM C1020 steel with a bore of 1.5 I have access to 1018,1045,1117 11L17,1215,A-36 steel for the pins.I also need to know how much clearance i need between the two.
   / replacing the bushings and pins on my TLB #2
My thoughts: Pins are easy to replace. Go with milder steel so the pins take the wear and just plan to replace them more often.
I'm probaby wrong, but those are my thoughts.
   / replacing the bushings and pins on my TLB #3
How about buying the pins and bushings from the dealer? That would save you the hassle of making sure you get the right grade of steel, heat treating, etc. Or are they terribly expensive or no longer available for your machine?
   / replacing the bushings and pins on my TLB #4
I prefer a mild steel pin, too. They are cheap to make from standard
rod stock. My experience on clearance is don't go much less than .015,
or much greater than .018. So say .012 to .018".
Remember that DOM is not a hard steel either.
   / replacing the bushings and pins on my TLB #5
I agree...the other posters were saying to use a milder steel without realizing a catastrophic failure can occur. If you can get the specs of the OEM pins and you can make them or have them made to those specs, then do that. But material substitutions, just because they fit, is not a good idea.
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52128)
2014 Yale 3 stage...
2012 PETERBILT 337 (A50854)
2012 PETERBILT 337...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
1968 International Harvester 856D 2WD Tractor (A50657)
1968 International...
2015 Dodge 5500 4X4 Bucket Truck (A52128)
2015 Dodge 5500...
NEW Woods Reverse Rotation 5ft Tiller (A52128)
NEW Woods Reverse...
