Replacing Shift Fork on 2005 DK45
   / Replacing Shift Fork on 2005 DK45 #1
joshgrammer01
Kioti dk45s
I have a DK45 that i have to hold the shifter in forward gear or it will jump back to neutral with any slight strain. I have been told that it is probably a bent shift fork. It does not jump out of reverse. Can any tell me if i will have to separate the tractor to do this? It looks to me that i can just remove the deck and column and get to it from the top. Any suggestions?
   / Replacing Shift Fork on 2005 DK45 #2
Check your transmission drain for any small 1/4 moon shaped steel keys. These are the synchronizer keys for the shifter. If you find the keys, you will probably need to replace the synchronizers in the shifter. That requires splitting the tractor. The fork can be replaced without splitting.
66in Light Material Bucket Skid Steer Connection (A52748)
66in Light...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
2015 CATERPILLAR 323FL EXCAVATOR (A51246)
2015 CATERPILLAR...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
John Deere 310A Loader Backhoe (A52384)
John Deere 310A...
