Replacing seals on BCS 725
/ Replacing seals on BCS 725 #1
AJD
Belchertown, MA
1956 JD 520
I am trying to help a friend work on a mid 1990's BCS 725. We are trying to seperate the back of the housing to replace an oil seal, and this sucker is resisting something terrible. It looks like someone has been in there before and used silicone to put it back together. Could it just be plain stuck? Or is there some linkage etc. that we are missing to be disconnected? I can't see anything in the parts diagram that should be holdiing it up, but I figured I would ask before using too much force on this. I don't want to rough up the housing so that it won't seal right when we put it back.
/ Replacing seals on BCS 725 #2
/ Replacing seals on BCS 725 #3
I think your talking about taking the rear plate off of the transmission. I had trouble also as the gasket sealer (a necessary part of the assembly) is real sticky and holds it all together a little too well. A careful working apart with a sharp wide flat blade,I think I ended up with a sheet rocking tool, did the job. I gently worked the tip in and then worked on the opposite side working it all apart. At some point it all just came apart easily. Good luck.
Jim
/ Replacing seals on BCS 725 #4
Just a quick note on removing the side cover on the BCS tiller. A heavy rubber hammer or a brass hammer on the opposite end of the tiller shaft breaks the seal quickly on the cover. No damage caused by screw drivers.
2013 PETERBILT 389 SLEEPER (INOPERABLE) (A60736)
2013 PETERBILT 389...
Golf Ball Picker Attachment (A59317)
Golf Ball Picker...
Auger and Bit (A60352)
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2020 Westfield MKX 100-83 Auger with Swing Hopper (A61307)
2020 Westfield MKX...
LIMA MAC 60KW GENERATOR (A58214)
LIMA MAC 60KW...
