Replacing safety covering on shaft between PTO and the connection to a Woods mower
   / Replacing safety covering on shaft between PTO and the connection to a Woods mower #1
dheastings
Allison Park, PA
Kubota L-185
I'm having a new metal shaft connecting my Woods RM990 finishing mower to my Massey-Ferguson 65 tractor and am being told that Woods only will sell the safety covering along with the shaft ($400). Is it not possible to buy the safety covering separately and install it on a perfectly good metal shaft?
   / Replacing safety covering on shaft between PTO and the connection to a Woods mower #2
i assume you are talking about the PTO shaft. that connects between the PTO on back of your tractor, and runs down to the gear box on the finishing mower?
if that is the case, any local farm store should have a new PTO shaft shield. tractor supply, farmking, farmandfleet.
the issue with some PTO shaft shields, is they make different types of PTO shafts, rated for different things as a result different shapes and size of PTO shafts are out there. and in that different shields to fit. most of the time new PTO shafts come with new shields already on them. not always though more so when repairing portions of the PTO shaft.
if above is case, make sure you cut your new PTO shaft to correct length. both shaft and shield. "this is a normal thing that should be done"
www.everythingattachment.com has a video of measureing and cutting shielf and shaft peices down to correct length.
google something like "cut PTO shaft" and there are variety of typed out instructions.
having to short of shaft pieces = shaft coming apart, possible, if you say go down into a ditch and then come back up, causing the finish mower to drop down real far.
having to long of a shaft pieces = when ya raise finshing mower up. and the 3pt hitch still has room to go up, but is being hung up due to the pto shaft pieces will not go up. (shaft bends / buckles and your in trouble)
again its normal to buy a slightly longer shaft, and then cut it down correctly. (every tractor and implement) will measure slightly different for min/max length. the PTO shaft will need to be.
Ryan,
Thanks for your thoughts. I went ahead and had a repair shop order and install a new PTO shaft, favoring safety over saving some money by using the existing inadequate shield. I did look at a tractor supply store near me and could not find a shaft anywhere near long enough for my purposes. I suppose a more exhaustive search eventually would have turned up something useful.
Dave
John Deere 648G2 Grapple Skidder (A52384)
John Deere 648G2...
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2006 International 4400 Lift All LOM15-55-1S 60FT Material Handling Bucket Truck (A51692)
2006 International...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
500 Gallon Boom Sprayer (A50123)
500 Gallon Boom...
2011 Ford F-550 Iowa 1015 3,200LB Crane Mechanics Truck (A51692)
2011 Ford F-550...
