Replacing relay
   / Replacing relay #1
Sawranch
DK55
My DK55 recently wouldn't crank. We replaced the battery and still no power. I had a mechanic come out said it was a relay. So I've bought the relay and now he won't answer. Any idea as to where this relay is located?
   / Replacing relay #2
The relays are located on the "firewall" in front of the fuel tank under the hood. They are fastened to that firewall and just plug into connectors on the wiring harness. BUT there are often several relays of the same type so you may have to hunt to get the right one. I think the starter relay is supposed to be the most outboard on the right side (driver's perspective) but I have read of cases there the connectors were switched so a different relay relay actually controlled the starter.
Since you have the replacement relay, go ahead and try it. But there are several other possible causes for this no-start problem, such as a dirty/corroded ignition switch or failed battery cables (failed under the insulation where it is not visible). There are MANY discussions of the no-start problem here on this list. I recommend a systematic approach with a schematic and a volt meter. If that sounds foreign, you may want to get help from someone with electrical troubleshooting experience.
2017 PETERBILT 567 TRI-AXLE MID-ROOF SLEEPER (A52472)
2017 PETERBILT 567...
2000 Ford F-650 (A50120)
2000 Ford F-650...
2016 Nissan Frontier Ext. Cab Pickup Truck (A50323)
2016 Nissan...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2006 CHEVROLET SILVERADO 4X4 PICKUP TRUCK (A52141)
2006 CHEVROLET...
2005 Peterbilt (A50120)
2005 Peterbilt...
