Replacing Radio Antenna on JD 6420
   / Replacing Radio Antenna on JD 6420 #1
WDP
Claxton, GA
JD 6420, Kubota L4330, Kubota L3130, JD 650
I purchased a better grade radio antenna to replace the one that came on my JD 6420 tractor. The antenna is extremely difficult to get to....front right section above the cab liner. The replacement antenna is a metal type with a base that will mount nicely on the rear sidebar support of the cab, but I can't find a way to gain access to the area. Any advice to novice operator would be appreciated!
   / Replacing Radio Antenna on JD 6420 #2
Hard to know what will be involved for your tractor but I can tell you that sometimes there isn't an easy way to do it. I used to be a Motorola two way technician years ago and can say that clean installations are sometimes very difficult. You may need to remove layers to get where you need to install this. Do you really need this?
Steve
Thanks for the reoly....After looking at the tractor further, I agree....it's tough to add an antenna without doing major surgery to the roof of the cab. Thanks again....have a great day!
   / Replacing Radio Antenna on JD 6420 #4
i have a 7410 jd with cab. on either side of the roof there should be something that looks like a piece of tape that is stuck on the cab. peel this off & that is where the mount for the antenna goes. you will need to remove about 16-18 screws on top of the roof to access the underside to mount the bracket & route the antenna cable. it really isnt that big of a job.get you a cordless drill or power screwdriver & it wont take long at all. just make sure you use a sturdy ladder,so you dont fall & break something.good luck
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2015 Ford F-450 Crew Cab Knapheide Service Truck (A50323)
2015 Ford F-450...
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
2011 L3 GENERATOR SET (A51222)
2011 L3 GENERATOR...
2009 Trail King TK110HDG-523 RGN 66 Ton Tri-Axle Lowboy Trailer (A49461)
2009 Trail King...
2009 HINO 185 18FT BOX TRUCK (A51219)
2009 HINO 185 18FT...
