Replacing Nimco Valve on Mahindra 2615
   / Replacing Nimco Valve on Mahindra 2615 #1
North Ga.
Mahindra 2615
My joy stick control on my tractor will not go into the float position and the front end loader moves downward very slowly. I read all the posts a it looks like I can use the Surplus Center 10 gpm 9-7401. I called this morning to order the valve and find out if my fittings from my nimco valve would transfer over to the new one. The tech help man said he had no idea if the fittings I have now would work on his valve. I found this to be a very odd response since I am sure they have sold many of these valves as replacements for nimco valves. I am hoping someone can tell me if the fittings will work in the new valve and is there another source to replace my nimco valve instead of the surplus center.
Butch
   / Replacing Nimco Valve on Mahindra 2615 #2
What fittings are on your old valve??
There four fittings that have quick couplers on them. There are three hoses that attach to fittings that are screwed into the valve.
   / Replacing Nimco Valve on Mahindra 2615 #4
How about brand and style and thread diameters and types (Male -NPT ?) of fitting.... Specification on port threads and diameters on valve should be readily available online for reference...
Dale
Here is where I am now. I purchased the replacement valve from surplus center. First problem my power beyond sleeve is too long. I ordered one from surplus center. Next the quick couplers base threads are too small. The brand valve holes for the quick couplers are larger. I measure them with a caliper to be .74 inch. My question is I cant seem to find a quick couplers that have a male threaded base. The couplers that came with the loader are made in Italy. Any ideas?
Butch
2019 MMDI 14ft T/A Utility Trailer w/ Fuel Tank (A48082)
2019 MMDI 14ft T/A...
2025 K0720 UNUSED Metal Farm Driveway Gate Set (A50860)
2025 K0720 UNUSED...
2019 Ford F-550 Knapheide Service Truck (A48081)
2019 Ford F-550...
2022 Club Car...
2003 International 4300 1100 Gallon Septic Truck (A48081)
2003 International...
Honda Foreman ATV (A50860)
Honda Foreman ATV...
